Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 12:55 AM
46yblock is starting off with a positive reputation.
Weird spark at plug
A friend of mine called me several days ago for help, as he couldnt get his Packard started. The vehicle is a beauty with a motor of less than 3000 miles.
First check was the Edelbrock, and there was gas getting to the primaries. Next we pulled a plug. I grounded it to the valve cover as he cranked, and surprise, there was spark but it was intermittent and jumping from the base of the center electrode, just above the porcelain, to the metal side of the plug.
The plugs were gas fouled, and I really couldnt tell if they had been running rich at that point. He said the car had initially fired and sputtered, and would only keep firing if the starter was engaged. Soon it wouldnt fire at all.
So, weird spark, great engine, we started thinking about the electronic ignition.
I went home and thought about an incident in the recent past on my Ranger. Winter, cold, tried to start it, died, pumped throttle a couple extra times, and it flat would not start for anything, even after waiting a day. Changed the plugs and fine ever since.
So I called him up and suggested putting in a new set of plugs. He did, it started immediately.
Maybe you guys know this but I didnt. Gas fouled plugs build up a coating that can only be blasted off, or burnt off in something like a charcoal fire. Even brand new plugs installed but then flooded and which fire a few times.
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
