Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-15-2008, 12:16 AM
Crush is starting off with a positive reputation.
'79 Bronco transmission question
Posting this for a buddy that's not online yet, he's got a '79 with the 351-M and guessing a C-6 (not sure about the tranny) it is lifted and riding on big tires, 39's I think he said. He lost all forward power coming home from work, trailered it home but then couldn't make it up the driveway even after cooling off. Happened a couple times in the past and when eng is shut off an turned back on it's regained forward power. Not so lucky today, it took more than a few tries and he barely got up the driveway. Okay, so here's the question, is this a tranny valve body issue or should he look at the torque converter first. Sorry, but theres a time zone issue so can't get any more info right now. He did have some water in the tranny awhile ago and drained pepto bismal out of it, but not sure how long ago that was either. Are there any tell tale signs to look for on the tq converter once it's out, like it smells burnt or is discolored from heat? Don't really know much about the guts of a C-6 or C-4 transmission and so turning to you guys for some help. Thanks!
Crush
  #2 (permalink)
Old 05-15-2008, 11:41 AM
BowTieHatr has a good reputation on FTE.BowTieHatr has a good reputation on FTE.BowTieHatr has a good reputation on FTE.
first thing to do is to check the fluid. if smells burnt, the trans is toast.
__________________
To whom it may concern;
Ford Senior Master Tech since '05
ASE Master Tech '04
6.0ing since '03.
6.4ing IF they tear up
  #3 (permalink)
Old 05-15-2008, 01:18 PM
husker is gaining momentum as a positive member of FTE.
I'm not a tranny expert, but would guess that the problem isn't the torque converter, but rather a worn tranny. He could change the fluid and add some Lucas tranny stuff and see if he can limp a little more out of it, but it is probably close to toast. I did the Lucas on mine when it wouldn't shift into 3rd and adjusted the front band and it is working again, but I know I only bought a temporary reprieve.
__________________
Del
2001 F250 SD PSD 4x4
78 Bronco
54 F250
48 F5
64 Thunderbird
  #4 (permalink)
Old 05-15-2008, 01:47 PM
Thanks guys, I'll let him know.
Crush
  #5 (permalink)
Old 05-15-2008, 01:49 PM
Matt99362 is starting off with a positive reputation.
I'm no expert but I've burned up my fair share. Your friend has a bad transmission. The dead give away is the pepto portion of the story. For right now (since he still has some forward movement) have him tighten the band. The C-6 only has one band and simply tightening it may help. Here are the directions:
Raise the truck on a hoist or jackstands.
Clean all dirt away from the band adjusting screw. Remove and discard the locknut.
Install a new locknut and tighten the adjusting screw to 10 ft. lbs. (13 Nm).
Back off the adjusting screw exactly 11/2 turns.
Hold the adjusting screw from turning and tighten the locknut to 35-40 ft. lbs. (47-54 Nm).
Remove the jackstands and lower the vehicle
If he still has no forward power, then it will be time to replace the transmission. Tell your buddy that when he replaces the transmission, install a transmission cooler. Also, he may want to snorkle the vent tube on the transmission up above the body so when he goes into deep water, he doesn't suck the water into the transmission.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
