Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 11:24 PM
speedrdr is starting off with a positive reputation.
dual rears-f-250?
i know it's been asked and answered about a dual rear setup not working on a 250 because of the frame width difference not having suitable clearance for the duals, but got a question with a twist. could a 350 axle be put under the rear if a frame pad/mount was fabbed? i.e. the frame rails be modified to accept the narrower axle from a 350 without compromising the strength of the frame? the thought crossed my mind that i could box the frame in front of and behind where the wheels would go and cut that section loose and bring it in the 4 or so inches and put a flat bed on it. is that too much sugar for a dime and a waste of time?
speedrdr
__________________
'90 F-250 XLT 4X4 7.3 non-turbo 5-speed
'91 Honda CBR 1000F sportbike-very fast, much fun
'84 Toyota Xtra-cab 4X4
'00 Mercury Sable DOHC V-6 (wife's car)
upcoming project...'49 Chevy panel wagon
  #2 (permalink)
Old 05-15-2008, 08:59 AM
starmilt is starting off with a positive reputation.
Much easier to find a dually rear fronm a pickup that came with a dually bed its a bolt in
the ones that are too narrow are the cab and chassis.
  #3 (permalink)
Old 05-15-2008, 06:53 PM
LilDuke's Avatar
He rides the short bus.
LilDuke is starting off with a positive reputation.
Isn't it only by 4 inches though?
__________________
Dave
'93 Ranger XLT 4.0, 4x4, 179,000 and counting. (For Sale)
'92 F-150 XL I6, M5OD, 4x4, 186,000 and counting.
'90 F-250 XLT 7.3 IDI, E4OD, 181,000 and counting.
Hiding in my own little corner of the world!
  #4 (permalink)
Old 05-15-2008, 08:23 PM
i'm not sure about the 4 inches. thought the cab and chassis was the wide one and the dually was the narrow one. gotta get my tape and remeasure, it looks like. thanks. maybe this will be easier to swap than i thought.
speedrdr
__________________
  #5 (permalink)
Old 05-15-2008, 09:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Cab and chassis frame is 34" wide.
The axle under it is the same axle that is under a SRW F 250 or 350, but the spring perches are moved in 1.75" on each side to line up with the narrow frame rails.
Cab and chassis trucks also have 2.5" wide rear springs.
All trucks that left the factory with a pickup box installed have a 37.5" wide frame and use 3" wide springs.
F 350 dually trucks have a 37.5" frame width, use 3" rear springs and have an axle that is 4" wider between the brake back plates.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #6 (permalink)
Old 05-16-2008, 10:34 PM
dyoung14 is starting off with a positive reputation.
me and my dad changed a f350 dully axle under an f250 and it work fine till he blew the motor up
  #7 (permalink)
Old 05-17-2008, 01:08 PM
thanks dave, knew that i was probably wrong on the widths. so looks like i need to cribbage me a dually axle.
speedrdr
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
