Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 10:45 PM
fordtruck44 is starting off with a positive reputation.
Dana 60?
I have a 1966 F-100 2wd with a dana 60 rear end. I don't know what kind of shape the rear end is in or the gear ratio, but how hard or expensive is it to rebuild one? Are the dana 60 capable of 400 horsepower?
  #2 (permalink)
Old 05-15-2008, 12:46 AM
jhooch's Avatar
jhooch is starting off with a positive reputation.
Are you sure it's not the Dana 44? Post a pic. Dana 60 is pretty stout unit. Semi-floating version used in Chryslers Hemi Cars of the late 60's.
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'66 F100 4X2 SWB Custom Cab, 352, 3sp.
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
  #3 (permalink)
Old 05-15-2008, 05:50 AM
jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.
I agree, the 60 has 8 lugs and would have been installed in F250s & 350s. Most half tons have 9 inch rears with a few 44s scattered in.
Someone could have swapped on in.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #4 (permalink)
Old 05-15-2008, 06:30 PM
garbz2 is gaining momentum as a positive member of FTE.
Some 60.2s are equipped with five lugs.
There out there.
What is your axle code on your warranty tag?
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive DOHC, EOD.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #5 (permalink)
Old 05-15-2008, 08:52 PM
Hakk is starting off with a positive reputation.
Dana 60 is one of the strongest, most capable rear diffs ever used in a production vehicle. 400 hp is nothing for a Dana 60.
__________________
'65 Ford 250 custom cab camper special
'83 Mustang GT dd with '93 Cobra motor HIT WHILE PARKED 2/2/08 Ask me what I think of Met Life Insurance company. >_< Sold empty shell 4/19/08
'89 GT my "new" beater.
'70 Mustang convertible carbed '89 roller cam 302
  #6 (permalink)
Old 05-15-2008, 10:06 PM
I will double check my code and let you all know over the weekend, thank you much.
  #7 (permalink)
Old 05-15-2008, 10:32 PM
camperspecial65 is starting off with a positive reputation.
no problem...post the rest of the tag info and a pic of the rig its in if you wanna..
- cs65
  #8 (permalink)
Old 05-15-2008, 11:07 PM
Grumpy Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
Quote:
Spicer-Dana 60.2's were optional on 1961/67 F100's.
5 lug 5.50" bolt pattern. With or without Limited Slip was available.
I've decoded at least 15 of these Spicer-Dana 60.2 axle codes here on FTE.
First digit of AXLE code is a letter, it's a Limited Slip.
First digit of AXLE code is a number: non Limited Slip.
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
  #9 (permalink)
Old 05-17-2008, 05:28 AM
BensDaddy's Avatar
BensDaddy is starting off with a positive reputation.
I've got a 60 on my 64 f250, how hard might it be to change the gear ratio, and the axles (I assume thats what I'll need to change from an 8 to a 5 lug pattern)?
__________________
The more I get to Know women, The more I like My Truck
If you ever reach total enlightenment while drinking beer, I bet you could shoot beer out of your nose. -Jack Handy
  #10 (permalink)
Old 05-18-2008, 11:44 PM
jhooch's Avatar
The F250 60's were full-floating designs whereas the F-100 60's were of a semi-floating design. You're best off to stay with the 8-lug.
__________________
Jhooch
  #11 (permalink)
Old 05-18-2008, 11:55 PM
BensDaddy's Avatar
I was thinking about swapping the full rear end butt stick with a 60. I'm not using the truck to haul or tow anything, just as a first restoration project.
__________________
  #12 (permalink)
Old 05-20-2008, 12:23 AM
jhooch's Avatar
Probably much easier to just swap in a 9-inch (easier to find and plenty strong) if you want a five lug. Are you going to do the front also?
__________________
Jhooch
  #13 (permalink)
Old 05-20-2008, 05:24 AM
BensDaddy's Avatar
I had planned on it. Looks simple enough to do, its just a two wheel drive so should just be a matter of hubs, right?
__________________
  #14 (permalink)
Old 05-20-2008, 05:29 AM
Quote:
No, You will need to swap the complete rear end, including springs if you want a softer ride.
John
__________________
  #15 (permalink)
Old 05-20-2008, 06:05 AM
BensDaddy's Avatar
For the rear, but the front should just be the hubs. Right
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
