Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 10:00 PM
Green_Monster is starting off with a positive reputation.
Question Searching for battery drain solution
Ok
This is not on my Ford truck but on my backhoe just looking for some troubleshooting guidelines.
I have a mystery drain on my batteries and am going to be troubleshooting in the morning. I know you have to isolate any possible drain points but what is teh correct procedure?
I remember although not sure if correctly using a test light on hooked to the negative battery terminal/cable if you ground it out to the frame and the light goes on then there is a draw on the battery by process of elimination you would find and fix?
Is this the correct prcedure is there a better one /tool?
Thanks
Matt
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 11:53 PM
3000 FPS is starting off with a positive reputation.
How about using an amp meter and putting it in series across the fuses with the fuses pulled out. Do this one by one until you find out which one has current draw that should not be there. You can also do this on the battery connections.
__________________
01 F250 4X4
05 F350 CC 4X4
Slammed 54 buick
  #3 (permalink)
Old 05-15-2008, 09:23 AM
69cj is starting off with a positive reputation.
3000 has the correct procedure, just make sure you do not put the meter across pos to neg while in the current function. It will cost you a meter. The fuse isn't quick enough to protect the meter.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
  #4 (permalink)
Old 05-15-2008, 12:55 PM
toolman05kr is starting off with a positive reputation.
Matt both the test light hooked between the neg. post and neg cable or an ammeter hooked the same way will work. considering the machine is probably exposed to extreme conditions you might want to disconect the alternator and see if your drain is still there, Its not uncommon for a diode to short out due to rust and corrosion.
__________________
ASE Master Auto/Medium and HD truck Tech. Master Auto Electrician.
  #5 (permalink)
Old 05-16-2008, 06:24 AM
1975 no fuses, so the test light idea is what I will go with. There are only a few elec sytems on the machine so I will disconnect and elimionate 1 by 1. Going to check the alt this AM.
  #6 (permalink)
Old 05-16-2008, 09:47 AM
lowell75 is starting off with a positive reputation.
Mismatch parallel batteries can asmuch be the problem ( one less than good cell will do it ! ). Replace both batteries at a time if parallel or go to a series setup!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
