Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 09:54 PM
xfornow is starting off with a positive reputation.
bad vibrations
I just traded my 04 F-250 4x4 for an 05 Excursion 4x4 6.0l and had the dealer swap my wheels/tires off of my truck to the X. (the X has 58k miles and had the original BFG's on it and my tires were pratically new, maybe 8000 miles on them) Now the truck has vibrations around 45mph and intermittently between 45 and 80mph. While the tires/wheels were on the truck they rode smoothly and had no vibrations. They are Michelin LTX M/S 265/70/16 (standard size) load range E. Prior to the tire swap the X was smooth. What would cause them to vibrate now and do you think the tires are the problem?
BTW The rear-end bearings are howling and the dealer is going to "rebuild" (replace bearings) the rear-end for me. Could the vibration be the rear-end getting worse?? It does not sound any worse than before, but I am wondering if that could be the culprit...the steering is fine (no shake transmitted through steering wheel)...any of your expert help is appreciated. Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 11:59 AM
betontheturtle is starting off with a positive reputation.
pull the wheels and remount them to the X and properly torque with criss/cross pattern 140ftlbs ( I think) see if that helps. Sometimes shops just run the nuts on with the impact and don't square them up.
  #3 (permalink)
Old 05-15-2008, 09:56 PM
Thanks I will try that tomorrow and hopefully that will correct the problem.
  #4 (permalink)
Old 05-20-2008, 09:14 PM
Did the remount...still vibrating. Dealer says next will try roadforce balance. We will do that when they repair the rear-end.
  #5 (permalink)
Old 05-21-2008, 01:50 AM
jhooch's Avatar
jhooch is starting off with a positive reputation.
The rear-end may be the culprit, sounds like you'll know soon.
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'66 F100 4X2 SWB Custom Cab, 352, 3sp.
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
  #6 (permalink)
Old 06-27-2008, 08:22 PM
Still vibrating
Had the rear rebuilt and it is great. The tires were roadforce balanced and I still have the vibration in the seats between 40 & 50 mph. I am going to start playing with tire pressures tomorrow. It looks like alot of you run 40-45 psi to quell vibrations. I will try that. Any more ideas??
  #7 (permalink)
Old 06-27-2008, 09:29 PM
FordxFour is starting off with a positive reputation.
Did you drive the X before the tires were swapped? How is the alignment. Just Ideas.
Edit: sorry, I re-read your post, you did drive it before the swap.
__________________
1993 F-350 CC dually 7.3 IDI (truly built Ford tough )
2005 Ford Excursion Limited V10/430 rears
2006 Carolina Skiff 19LV/115 Suzuki 4stroke
2007 Keystone Outback 28rsds
  #8 (permalink)
Old 06-29-2008, 07:20 PM
sierra6 is starting off with a positive reputation.
My 05 Ex had alignment problems (caster and toe in) that caused the right front to shake at 70 mph. Go get the truck alignment checked.
  #9 (permalink)
Old 06-30-2008, 08:20 AM
tloc357 is starting off with a positive reputation.
Had this same scenario happen to me on my 02 Ex. Same tires as you have. Vibration started right after I bought the tires so I assumed the tires were bad. I replaced the following to no avail.
. front end aligned
. tires road force balanced
. checked rear end and changed out fluids
. new u-joints in drive shaft (helped a little)
The final solution was I replaced the drive shaft with a new oem one. Vibration gone, rides as smooth as silk.
Hope this helps.
  #10 (permalink)
Old 07-01-2008, 02:47 PM
Mountain Cat's Avatar
Mountain Cat is starting off with a positive reputation.
I had a "rumble strip" like vibration at 50 to 60 mph and it drove me nuts. It started this spring and I was told it was my tires. After I had them balanced, and they were off a bit, the vibration continued. I finally inspected my u-joints on my rear driveshaft and they were worn out pretty bad. I replace them and now my Ex rides nice and smooth.
-Brian
  #11 (permalink)
Old 07-01-2008, 03:16 PM
H1449-6 is starting off with a positive reputation.
Sometimes it's a bad tire. Rare, but it happens.
__________________
2003 7.3L PSD Excursion Limited 4x4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
