I have a 52 ford with a 239. I was having problems with the starter so I replaced it tonight but now the starter won't turn over at all. Does anyone have any clue on why? I need to get this done tonight because it is my daily driver and I need it to get to work tomorrow. It has new batt wires and a new solinoid.
I know you said you have new cables but recheck every connection for any type of dirt or corrosion. Also, make sure you grounds are good and clean. It sounds like you have a dirty connection somewhere.
Hopefully, the starter isn't defective and is grounding inside somewhere.
BTW, the new solenoid, does it have one or two small studs?
__________________ Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup
48 F-1 panel truck
49 F-1 panel truck (half apart/together)
49 8N tractor
48/51 F-4 flatbed (2 in 1) My web site
It just has one stud comming out of the front with the two bigger ones on the sides for the battery cable and the starter cable. I tried it with a 12v battery but no luck.
I did try that but ot didn't work. I just checked the connections and they are all clean. The old starter worked right before I changed it. It just turned too slow to start the truck.
BTW, I thought it was the battery but that is pretty new so I took the old starter to NAPA and they said it was bad. I don't know if that helps anyone.
If jumpering the solenoid didn't work and all of the connections are good it sounds to me like you got a bad starter.
The only think you could do is take the starter out and bench test it. If you do bench test it make sure your install some 1/4" nuts on the ends of the long bolts going through the starter so it doesn't come apart.
When you installed the starter did it come apart at all? I know these starters like to fall apart when you're taking them out or putting them in if you're not careful. If it did separate at all you might have dislodged the brushes. Also, if it went in cocked it could have bound up with the flywheel. Also, make sure you have the bracket from the top bolt on back of the starter and the oil pan installed. If you don't the starter could get cocked also.
49 F-2 pickup
48 F-1 panel truck
49 8N tractor
Good luck, I have to sign off for the night but if this has helped please post to let me know. If you find out something different I would like to know what you find.
49 F-2 pickup
48 F-1 panel truck
49 8N tractor
I just saw your last post right after I clicked the post button. Man, you've got a stumper there. The circuit for the start is pretty simple, I just wonder if the starter is defective.
49 F-2 pickup
48 F-1 panel truck
49 8N tractor
