Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 09:07 PM
falcon1964 is starting off with a positive reputation.
65 5.0 headers
What headers will fit with an '87 5.0 engine in a 1965 f100?
  #2 (permalink)
Old 05-14-2008, 09:11 PM
Long Tube Headers
  #3 (permalink)
Old 05-14-2008, 11:25 PM
daveengelson's Avatar
daveengelson is gaining momentum as a positive member of FTE.
Since 302 was not available in 65 will need to look for set that fits later model truck, believe same from 67 thru at least 72 and perhaps later. Purchased set of Hooker long tubes, had some minor grinding to get additional clearance where the header flange meets the crossmember on the passenger side. Also had to lift engine slightly to get the passenger side headers in position. I used hedman offset extentions, purchased thru 'summit' to address issue of routing pipes around transmission crossmember. Posting thread of pic's where member modified crossmember to address the issue. Believe 'Sanderson' will make headers to fit.
http://www.ford-trucks.com/user_gall...=79912&width=2
__________________
'problem with engaging in useless activity is never knowing when your done'
Last night I was looking at the stars and I wondered... where the hell's my ceiling!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #4 (permalink)
Old 05-15-2008, 11:16 PM
fordtrucksforever is starting off with a positive reputation.
Stock shorties should work great.
  #5 (permalink)
Old 05-15-2008, 11:34 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is starting off with a positive reputation.
Quote:
Ditto I had a 72 Fastback and ditched the Cleveland for a HO and there was tons of room. Came a bit close to the steering box but otherwise it was a drop in the bucket.
GrumpyBobby/Mildredd - Photobucket - Video and Image Hosting
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #6 (permalink)
Old 05-16-2008, 06:40 AM
If recall, went to long tube because of the power steering upgrade. If considering going bendix power steering, don't think shorties, or long tubes will work.
__________________
dave
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
