Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 08:53 PM
skosler's Avatar
skosler is starting off with a positive reputation.
1987 ZF5 460 onto a 1973 460
I got the tranny and the motor, but what do I have to do to get them 'happily' together? The 1987 460's were externally balanced and my engine is internally balanced. I think I read somewhere that I need to get the flywheel to a zero balance for it to work correctly. What else do I have to do?
thanks
  #2 (permalink)
Old 05-15-2008, 08:56 PM
skosler's Avatar
anyone???
thanks
  #3 (permalink)
Old 05-15-2008, 11:23 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Wait more than 3 min....
What's it going into? The ZF needs a hydraulic clutch. Drive shaft, cross member, speedo hook, make sure your trans uses the cable not electronic or you'll have to retro an electronic speedo.
4wd or 2wd versions, watchout....
  #4 (permalink)
Old 05-16-2008, 12:30 AM
big hoss 29's Avatar
Resident Platypus
big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.big hoss 29 has a great reputation on FTE.
Quote:
Not being an ass, but he waited 24 hours and 3 minutes........
__________________
When confronted with other people's problems, I like to use these touching words of wisdom........
"get away from me you unlucky jerk before your luck rubs off on me!"
  #5 (permalink)
Old 05-16-2008, 08:08 AM
skosler's Avatar
Quote:
thanks hoss
I am specifically asking about the flywheel to motor match. I think there may be some spline issues, but I handle that. I have a complete 1987 f350 with the motor and tranny and I am wanting to put it in my 1978 f100 with a 1973 460. My engine is internally balanced and the flywheel for the zf came off of a motor that is externally balanced. Does that matter?
  #6 (permalink)
Old 05-16-2008, 08:09 AM
skosler's Avatar
both are 2wd and I will work out any driveshaft issues.
thanks
  #7 (permalink)
Old 05-16-2008, 10:48 AM
Sorry. Thanks for the correction.
On the flywheel, try posting the question in the BB 385 engine forums. There is lots of traffic here and this has been on long enough for an answer (usually) so I'd try the engine area--more engine specific traffic.
Good luck.
  #8 (permalink)
Old 05-16-2008, 02:25 PM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
You can have the 87 flywheel rebalanced to be the same as the 73s at a good machine shop.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
