Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 08:52 PM
65fordguy's Avatar
65fordguy is starting off with a positive reputation.
WHAT DRIVESHAFT!! 86 5.0ho with 60s or 70s C6
What driveshaft to get!?!!
The truck had a shaft that seems to be right length but the yoke will not go on far enough to seat correctly...it will seal the transmission to keep fluid from coming out though. It needs to go in about another inch or so to be right. could there be rust or something in there keeping it from going on??
If I take the shaft off...what can I put in to stop it from leaking 3 dollar a quart fluid.
Is there a good modern driveshaft that will work?
The truck has a 5.0 HO mated to a C6 sitting on 390 perches.
the transmission mounted right to the truck brace...where as
the 390 that was in it did not. it just was resting on the rails.
The truck had originally had a inline 6 so I feel like the drive shaft was for that.
What do you think??
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 09:49 PM
instig8r63's Avatar
instig8r63 is starting off with a positive reputation.
Jack the rear of the truck up on wheel stands to stop the fluid from leaking out and pull the driveshaft out. Throw the old driveshaft aside. Call your local driveshaft shop, tell them your trans/rear-end combo and tell them to make you a new driveshaft. They will ask you to take a measurement (I can't remember exactly where, but I think it's from the end of the tailshaft housing on the trans to the flat part of the pinion yoke where the u-joint straps go). This way you will have a brand new, balanced driveshaft. You can get aluminum, steel, carbon-fiber, etc.
__________________
Bobby
1972 F100 Short Bed
1963 Uni Longbed 390/C6
1967 Mustang Fastback 390 4-speed
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
