1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Diesel Cut????
Old 05-27-2008, 08:51 PM
josegiron83's Avatar
josegiron83
josegiron83 is offline
Today i put a fuel pump given and when i tried to start the car doesnt start i am angry now because this is what the scanner indicated???? tomorrow we are going o put the scanner again???
  #32
Old 05-27-2008, 09:48 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Subscribed
  #33
Old 05-27-2008, 11:04 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Josegridiron:
Some troubleshooting ideas for you:
When you turn the key to on, wait to start light comes on and eventually goes off. During this time, can you hear your fuel pump running?
When you turn to starter from on with the ignition, can you hear injectors cycling? I know on mine, when I turn to on and wait for the glow plug light to go out, I can hear injectors cycling. If you cant hear this, then I wonder if your ECM, PCM computer boxes are unplugged or you have a wiring issue?
The other way to check you are getting fuel from the primary pump and to the engine is to remove your secondary fuel filter on the engine, have someone turn ignition to on and see if the bowl fills up. (Be careful, they have to be ready to turn to off right away!)
Had you just changed oil or fuel filters before this happened? You could have a vacuum leak in the fuel causing a no start, you could have not enough oil in the oil pan, verify oil on the dipstick is up to full or close to it?
Hope this helps.
  #34
Old 05-28-2008, 09:10 AM
josegiron83
Yes when i turn the key to on i hear the fuel pump and i can hear the injectors cycling, and yes i cheked in the secondary filter if its pressure, yes whit this problem i changed the oil filter and the diesel filter are ok
What it the ECM PCM computer???
i think is the main computer of injection???
If where the cam sensor the scanner should appear???
  #35
Old 05-28-2008, 09:17 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I'm not so sure the CPS would throw a code. The computer just thinks you stalled the engine
The ECM or PCM is the "computer". The brain. Powertrain Control Module.
  #36
Old 05-28-2008, 10:54 AM
josegiron83
So you think if Its the computer the scanner will not showed it?????
  #37
Old 05-29-2008, 03:52 PM
Beerstalker's Avatar
Beerstalker
Beerstalker is offline
I would start looking over the wiring harnesses to make sure you don't have a short somewhere. There were a few years of Super Duties that were known to have wiring harness issues that could cause all kinds of issues with starting and rough running.
You may also think about asking a moderator to move your thread down to the 6.0L forum, as there are some guys down there that really know their stuff, and htey don't make their way into the general Super Duty forum too often.
  #38
Old 05-29-2008, 08:28 PM
michael521's Avatar
michael521
michael521 is offline
I am sorry that I do not have any experience with this engine or problem to share , But I think it is great how you guys are trying to help, I think this is what this type of forum is all about, I hope you get your truck fixed soon.
johnnythegent
07-07-2011 03:23 PM
Rusty_S
General Automotive Discussion
12-08-2010 01:42 PM
embry1123
03-22-2010 09:13 PM
josegiron83
Electrical Systems/Wiring
05-23-2008 10:20 PM
JTHill24
Aerostar
18
03-02-2008 02:09 AM
Quick Reply: Diesel Cut????
