Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 08:23 PM
fryford is starting off with a positive reputation.
01 Won't Rev Past 3,500.
I just recently bought second hand an 01' Ranger. When I rev it in neutral, it won't go past 3,500 rpm. It just rises and falls quickly. Somebody mentioned to me a rev limiter? Can I have that removed by any chance, if that is the problem? What do you folks recommend I do?
Thanks in advance,
Shane.
  #2 (permalink)
Old 05-14-2008, 09:32 PM
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
If it is an automatic, it is rev limited to about 3k rpm. Most Rangers are limited to about 6250 rpm top end. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #3 (permalink)
Old 05-15-2008, 12:49 AM
epion04 is starting off with a positive reputation.
on the automatic is the 3k revlimit only when in neutral or all the time? i have been working on an 01 ranger 4.0 that even in drive nailing it down the road will not go over 3.5k top end.
i know that the 3k limit is normal when in neutral but is it the same in drive?
  #4 (permalink)
Old 05-15-2008, 06:00 AM
wendell borror has a good reputation on FTE.wendell borror has a good reputation on FTE.
You can have the rev limiter removed with a bama engine programer. My 04 4.0 ranger would rev up to 5,500 going up through the gears with a manual tranny. I don't know why you need to rev past 3 grand in neutral, but the bama will delete the rev limiter.
BamaChips Tuning
__________________
08 ford fusion, black, 4 cylinder auto with sunroof and spoiler.
07 red fire mustang gt with manual tranny.
87 jeep wrangler, 258 6 cylinder, 5-speed.
88 ranger xlt 4x4, blue, reg-cab, 5-speed, 2.9 V-6
  #5 (permalink)
Old 05-15-2008, 10:23 PM
MazdaRangerGuyInSTL is starting off with a positive reputation.
If you are cutting out at 3000+ rpm while driving the truck (in gear or in drive), and if there are no diagnostic codes set in the PCM, then replace the Cam Sensor and Cam Synchronizer.
You can purchase this brand new in the "Dorman" brand.. it is very high quality, and comes with the synchronizer, the sensor, AND the installation alignment tool. (And is about the same price as the remanufactured synchronizers that often aren't aligned quite right)
  #6 (permalink)
Old 05-16-2008, 12:01 AM
Well, a thousand thank you's amigos. I appreciate how quick and knowledgable your replies were... Glad I posted, thanks you kindly and all the best...
Shane.
  #7 (permalink)
Old 05-16-2008, 12:09 AM
Sorry, just one quick question... Where do you pick up a Bama Engine Programmer? and how much do they go for? I'm completely in the dark as this is the first vehicle I've owned... Thanks again fellas.
Shane.
  #8 (permalink)
Old 05-16-2008, 05:53 AM
Just click on bamachips tuning. The last time I checked, they were a round 390.00. They also improve shift point on an auto tranny and adjust speedo for larger tires or gear swaps.
__________________
  #9 (permalink)
Old 05-16-2008, 08:39 AM
Only in neutral. If it will not go higher than 3.5k, you have other problems, and a programmer will be of no help. A clogged exhuast system will exhibit this symptom among other things. jd
__________________
  #10 (permalink)
Old 05-16-2008, 09:48 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Since when was Dorman brand anything quality? Dorman knows how to make a nice looking product with the appearance of quality, but I have never had any luck with Dorman brand stuff.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDry filter
  #11 (permalink)
Old 05-16-2008, 09:59 AM
scottm is starting off with a positive reputation.
Fry, is the problem that it wont go past ~3k in neutral, and you're afraid it wont on the road, either?
They have a limiter to keep from blowing up the engine in neutral, theres no reason to have an auto above 3k in neutral, anyway.
How does she drive?
And welcome to FTE!
Scott
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
