Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 09:00 PM
yotee is starting off with a positive reputation.
any one in sacramento area that knows this carb stuff?
my 66 has a 90's roller 302 in it (yes i veriffied that it has a steel gear on the dizzy) and a 600cfm(?) holley. the holley took a crap on me, and we adjusted everything we knew to adjust. i bought a new 600 cfm holley and now i just don't know how(and am not comfertable) adjusting it my self. i was able to adjust the idle up enough for it to keep running while in drive. but i need it adjusted properly.
i miss my 65 that started every time i turned the key(no help from the peddle needed) and ran like a raped ape!
is there any sac area folks that could give me a hand(and possiblly show me the non fuel injected side?)?
mike
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-15-2008, 01:50 AM
jhooch's Avatar
jhooch is starting off with a positive reputation.
Usually Holley's will be pretty close right out of the box. Are you sure it's a carb problem?
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'01 F250 CC SB 4X4, 7.3 powerstroke, 6-sp manual
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
  #3 (permalink)
Old 05-15-2008, 11:00 AM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is gaining momentum as a positive member of FTE.
Get a vac guage on it, if your mixture is that far off ok, but my guess is you got a loose vac line somewhere. (Base of the carb, brake line, other lines, back of the intake.. start looking if the gauge tells it to be the case.)
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #4 (permalink)
Old 05-15-2008, 06:26 PM
Quote:
thanks, i'll check it out. shuoldn't be too hard, there is only 2 vac lines. one to the vac advance and one to the trannie.
mike
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
