05-14-2008, 07:53 PM
1989 E350 fuel pump issue
1989 E350 with 460 engine.
The high pressure fuel pump under the frame won't start, not getting any voltage. Direct connecting the pump works well. Fuel relay under the hood switches through, but wire disappears in harness and I can't track it. I thus ran a wire direct from the relay to the pump and the truck runs well.
However, before this happened, the pump used to just start up upon turning the ignition key and stopped humming when the car wouldn't start. Is there a pressure switch in the fuel system which might have been the real cause the pump wasn't running before short wiring it? Did I create a safety concern? If there is a pressure switch: where could I find it? Any suggestions are much welcomed.
