Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 07:01 PM
carcrafter22's Avatar
carcrafter22 is gaining momentum as a positive member of FTE.carcrafter22 is gaining momentum as a positive member of FTE.
Rear axle swap info for everyone!!!
Some useful info on rear axles.
93 crown vic 64.5" outside hub to hub 28 spline with limited slip or open diff
98 explorer 59.75" outside hub to hub 31 spline with limited slip in the V8 models
07 crown vic 70.0" outside hub to hub 28 spline with limited slip or open diff
I have all three of these rear axles in my shop and measured them from outside hub to outside hub with the disc brake rotors on. These axles are all very cheap and can be had for betweed $150 - $400 depending how resourceful you are. I am going with the 93 crown vic rear axle that measures 64.5" since I have 2007 dodge magnum wheels which will make the wheels tuck in just a hair and with a 3/8" spacer on each side with make them dead even with the fenders edge.
So I just thought I would share this info with everyone in case anyone is looking for a cheap stout rear axle with posi and disc brakes. Maybe is can be a sticky or something who knows.
__________________
Project Grocery Getter: 67 F100 sc/sb 06 crown vic front suspension and rear axle, isuzu 3.9L diesel, 700R4 trans. Lowered 5" rolling on 18" Looking for 30-32mpg using vegi oil. DIESEL BABY!!
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
