Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 06:56 PM
Beaus Truck is starting off with a positive reputation.
Lower ball-joint
How do i get the halfshaft out of the way to replace the lower ball-joint?
  #2 (permalink)
Old 05-14-2008, 07:04 PM
Twinsdad98 is starting off with a positive reputation.
I'd assume with a BFH (Big Freaking Hammer)
__________________
2004 Black Lariat F150 Supercrew 4x4
Roush Suspension Kit, Mark LT bed rails, Truxedo Low Profile tonneau cover, Euro Tail lights, chrome handles, Edge, Volant CAI
Summer Wheels : NS Racing Black/Chrome, 20X8.5, Cooper Tires, 305/50R20s.
Project: 1950 F1
Previous:
89 Probe GT; 86 Bronco II (ex gave it away )
  #3 (permalink)
Old 05-14-2008, 07:05 PM
I got one of those but it seems like i need to take out the half shaft to get it out. How in the world do i do that.
  #4 (permalink)
Old 05-14-2008, 07:39 PM
Mattd17
mattd17 is starting off with a positive reputation.
this is kinda involved, but not too bad to do.... you need to remove the entire steering knuckle, and then the axle will move enough to get the joint off. just take the brakes off, rotor, the axle nut, tie rod, and unbolt the hub from the back of the knuckle.... then you will be able to pop off the knuckle to get the room you need. goodluck.
__________________
2006 F150 SCREW 4X4 5.4..... Magnaflow SISO, Edge Evolution Programmer, 6" RCD Lift, Nitto TerraGrappler AT's (for now), Fire and Ice LED bar, Under hood engine lights, Glove box lamp, Dual style Fog/Driving lamps.
  #5 (permalink)
Old 05-14-2008, 08:02 PM
What if i unbolt the halfshaft at the axle with the six bolts, will the axle slide out them?
  #6 (permalink)
Old 05-14-2008, 08:06 PM
Mattd17
you will have to remove the axle nut on the outside of the knuckle.... and then the whole hub might still have to be unbolted from the inside of the knuckle. im not sure if you can wiggle it out or not, you might get lucky. when i had mine apart, i was changing knuckles anyhow, so i didnt try it that way.
__________________
  #7 (permalink)
Old 05-14-2008, 08:16 PM
Ill have to try. I am replacing the lower control arm and looking for the best way to do so.
  #8 (permalink)
Old 05-15-2008, 10:09 AM
kaerch is starting off with a positive reputation.
i just did lowers the other day. knock off the dust cap, there is a nut behind it-remove. it was easier for me to remove the whole knuckle to do the b/j's. i pressed em in and out. i would imagine with the whole arm though you could get it out without disassembling anything else. pry it down to get the stud out once its loose. then hit the bolts at the frame.
i will say i was shocked at the design of our front axles and hubs. a small 13mm nut for the axle, and the splines on the hub and axle look like an abs exciter ring. just not what i expected, thats all. btw the knuckle is heavy as heck with the caliper and rotor still on.
  #9 (permalink)
Old 05-15-2008, 11:39 AM
So just smack the ball joint loose unbolt the axle and them unbolt the control arm. Then i shoud be able to get the ball joint out.
Thanks for all the help.... this should be a fun weekend
  #10 (permalink)
Old 05-15-2008, 12:33 PM
mitch150's Avatar
mitch150 is gaining momentum as a positive member of FTE.mitch150 is gaining momentum as a positive member of FTE.
That's why it is easier to remove the caliper and rotor, that's what I did when I changed my ball joints. Was relatively easy
__________________
2005 F150 XL 5.4L ext.cab,longbed 4x4
Volant w/ ram air intake,Magnaflow catback duel exhaust, 3" Bushwhacker flares, Eagle alloys(7 lug rims), BFG All Terrain T/A's, JVC KD-NX 5000 W/ nav, dvd, Sirius, am fm cd w/ 12 disc changer, chrome w2w nerfs, Xcal ll Troyer custom tunes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
