Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 06:38 PM
wreedZ71 is new and has a neutral reputation at this point.
Knuckle rubbing coil spring after Autospring
Hey guys I have had a 2" A/S on for about 6000 miles now and I just noticed that the knuckle is rubbing slightly on the coil spring. Is this normal? I really dont like it rubbing at all.
Any ideas? Thanks
__________________
2007 Ford F-150 5.4L 4x4 King Ranch, 2" A/S, Edge EVO, Volant CAI, Factory NAV
2008 Lexus IS250 Black on Black
2005 Mercedes CLK-320
2007 Honda CR-V EL-X 4WD
2004 Chevy 3500 Duramax Dually 4x4
1997 Chevy 1500 Suburban 2WD
  #2 (permalink)
Old 05-14-2008, 07:37 PM
MBBFord's Avatar
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
Noticed the same thing.
After 40K + miles with no ill effects, I don't worry about it.
__________________
Matt
STGs Minions - Special Forces/Mud Division
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #3 (permalink)
Old 05-14-2008, 07:41 PM
Mattd17
mattd17 is starting off with a positive reputation.
do either of you two have the new "offset" design? auto spring made this new style to prevent just this from happening. but, as MBB stated, it wont hurt anything.
__________________
2006 F150 SCREW 4X4 5.4..... Magnaflow SISO, Edge Evolution Programmer, 6" RCD Lift, Nitto TerraGrappler AT's (for now), Fire and Ice LED bar, Under hood engine lights, Glove box lamp, Dual style Fog/Driving lamps.
  #4 (permalink)
Old 05-14-2008, 07:42 PM
yes I specifically bought the offset design on ebay!
__________________
  #5 (permalink)
Old 05-14-2008, 07:49 PM
could we have installed the kit backwards or something?
__________________
  #6 (permalink)
Old 05-14-2008, 07:55 PM
Mattd17
no, it is impossible to install backwards due to the bolt pattern.
__________________
  #7 (permalink)
Old 05-14-2008, 08:06 PM
hmm i wonder if it it from when i put the truck on the lift at the shop to rotate the tires? the tires are completely off the ground then and the suspension sits on the coil spring almost at that time.
__________________
  #8 (permalink)
Old 05-14-2008, 11:28 PM
If someone has time could you post pics of how and where yours is rubbing, I want to see if mine is doing the same.
__________________
  #9 (permalink)
Old 05-15-2008, 04:45 AM
tylus's Avatar
tylus is starting off with a positive reputation.
you'll see a little spot about 2" long where the upper control arm contacts the coil spring when the front suspension is fully drooping.
the Offset design wasn't to correct this issue. The AS originally came with middle supports that were welded striaght up and down. The new version comes with middle supports that are welded at a ~45 degree angle. This allows the spacer to fit without contacting the coil-over perch.
If you look at any other Leveling kit, you'll find they all do this also. It's just the nature of the beast and geomety when you push your coil-over downward by 2" to 2.5"
btw, at least 10k with mine installed and 0 functionality issues. the rubbing spot ain't exactly pretty, but it's 100% mechanically sound
__________________
Previous Fords:
1984 F-150 (302 V-8), 1989 F-150 (300 I-6), 1993 Bronco (302 V-8), 1994 F-150 (300 I-6)
1994 F-150 (302 V-8), 1995 Mustang (3.8 V-6), 1998 F-150 (4.2 V-6), 2003 Mustang GT (4.6 V-8)
  #10 (permalink)
Old 05-15-2008, 02:40 PM
Tylus I know this is asking alot and being anal, but when you have time could you snap a couple pics where you are rubbing so i can compare?
I just dont like the idea of rubbing, expecially metal on metal.
But I think this only happens when the truck is on a lift and tires off the ground, correct? Does it ever rub during normal driving conditions?
__________________
  #11 (permalink)
Old 05-15-2008, 04:40 PM
MBBFord's Avatar
Only time it rubs is when the suspension is at full drop...like when the truck is lifted in the air.
__________________
Matt
  #12 (permalink)
Old 05-16-2008, 03:57 AM
tylus's Avatar
I'll see if I can grab some pics...but it's extremely hard to see with the tire installed
I've only noticed it 2 times. 1 when I did an oil change using a Frame lift...and the other was when I had 2 wheels on the ground and 2 in the air
but yeah, you're right, only when suspension is in full droop is the upper control arm going to contact.
__________________
Previous Fords:
  #13 (permalink)
Old 05-16-2008, 04:05 AM
tylus's Avatar
^^^there ya go. I had a pic laying around that I just zoomed in on. that little spot that looks like grease on the coil-over is the contact area
__________________
Previous Fords:
  #14 (permalink)
Old 05-16-2008, 06:30 AM
SDTruckMan is starting off with a positive reputation.
wreedZ71 could you post some pictures of your truck im interested in seeing what the 07's look like with a 2 inch AS.
__________________
2007 F150 4X4 - SuperCrew FX4
Dark Shadow Grey
1st Mod - LineX
2nd Mod - Tinted Front Windows
3rd Mod - Truxedo Tonneau Cover
4th Mod - Mag Light Mount
5th Mod - WeatherTech Front Liners
6th Mod - Edge Evo
  #15 (permalink)
Old 05-18-2008, 10:01 PM
Sure I will get some in the morning. I just bought a Lexus IS 250 also! I am excited.
I am on the stock KR 20s also. Im buddy said I look badass in the front coming down the highway, you can see the lower control arms and coilsprings and it looks stout.
Thanks Tylus that is exactly what my truck looks like. I wont worry about it.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
