Hey guys I have had a 2" A/S on for about 6000 miles now and I just noticed that the knuckle is rubbing slightly on the coil spring. Is this normal? I really dont like it rubbing at all.
Any ideas? Thanks
__________________
2007 Ford F-150 5.4L 4x4 King Ranch, 2" A/S, Edge EVO, Volant CAI, Factory NAV
2008 Lexus IS250 Black on Black
2005 Mercedes CLK-320
2007 Honda CR-V EL-X 4WD
2004 Chevy 3500 Duramax Dually 4x4
1997 Chevy 1500 Suburban 2WD
do either of you two have the new "offset" design? auto spring made this new style to prevent just this from happening. but, as MBB stated, it wont hurt anything.
__________________
2006 F150 SCREW 4X4 5.4..... Magnaflow SISO, Edge Evolution Programmer, 6" RCD Lift, Nitto TerraGrappler AT's (for now), Fire and Ice LED bar, Under hood engine lights, Glove box lamp, Dual style Fog/Driving lamps.
hmm i wonder if it it from when i put the truck on the lift at the shop to rotate the tires? the tires are completely off the ground then and the suspension sits on the coil spring almost at that time.
__________________
you'll see a little spot about 2" long where the upper control arm contacts the coil spring when the front suspension is fully drooping.
the Offset design wasn't to correct this issue. The AS originally came with middle supports that were welded striaght up and down. The new version comes with middle supports that are welded at a ~45 degree angle. This allows the spacer to fit without contacting the coil-over perch.
If you look at any other Leveling kit, you'll find they all do this also. It's just the nature of the beast and geomety when you push your coil-over downward by 2" to 2.5"
btw, at least 10k with mine installed and 0 functionality issues. the rubbing spot ain't exactly pretty, but it's 100% mechanically sound
wreedZ71 could you post some pictures of your truck im interested in seeing what the 07's look like with a 2 inch AS.
__________________
2007 F150 4X4 - SuperCrew FX4
Dark Shadow Grey
1st Mod - LineX
2nd Mod - Tinted Front Windows
3rd Mod - Truxedo Tonneau Cover
4th Mod - Mag Light Mount
5th Mod - WeatherTech Front Liners
6th Mod - Edge Evo
Sure I will get some in the morning. I just bought a Lexus IS 250 also! I am excited.
I am on the stock KR 20s also. Im buddy said I look badass in the front coming down the highway, you can see the lower control arms and coilsprings and it looks stout.
Thanks Tylus that is exactly what my truck looks like. I wont worry about it.
__________________
