Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 05:43 PM
bigredneck47240's Avatar
bigredneck47240 is starting off with a positive reputation.
cb's/linears
i dont really know where to post this in here or if it should even be in here but im wanting to know about cb's and linears if anyone can help me it would be greatly appreciated thanks in advance
__________________
Sandifer
02 F-150 4.2L V6
Nothin Special
  #2 (permalink)
Old 05-15-2008, 01:39 AM
Bluegrass 7 is starting off with a positive reputation.
Respectfully, I do. The the linear is illegal to use with a CB on 11 meters. I am a lisc. Extra class Amateur Radio operator, so will not assist you with such an equipment setup.
  #3 (permalink)
Old 05-15-2008, 06:31 AM
John Luther is starting off with a positive reputation.
Bluegrass.... What is the legalities of using linears? We run linears in our hunting trucks. If we didnt, we wouldnt be able to talk to each other in the woods. What is "11 meters"? Is a regular CB radio 11 meters?
  #4 (permalink)
Old 05-15-2008, 11:19 AM
KingRanchMan02's Avatar
KY KR lover
KingRanchMan02 is gaining momentum as a positive member of FTE.
The FCC regulates the maximum power output for CB radio to 5 watts maximum. Anything above that is considered illegal. CB radio operates in the 26.965 - 27.405 MHz frequency range and 11 meters is a ham radio band that includes CB radio.
__________________
John
aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege
5.4L 3.55 LS, 4x2
Diablosport Predator Programmer, K&N filter.
  #5 (permalink)
Old 05-15-2008, 09:12 PM
So what do we need to do to be legal? If we dont use the "Hot Box" then we would never be able to hear each other...
  #6 (permalink)
Old 05-16-2008, 12:23 AM
montanafordman's Avatar
montanafordman is starting off with a positive reputation.
using a good antenna setup is the first and most important step and should give you some decent range - however due to power limitations and the atmosphere you can be limited with CB. I have been involved in some ham radio contests where I could hear people clearly several states away that were transmitting on only a couple watts with a VERY good antenna setup. There are many very good reasons the FCC places these sort of restrictions on frequency use because you may very well be interfereing with other users. (ESPECIALLY using modified equipment if not done properly or legally) If its that big of an issue I'd suggest either getting your ham radio license (I have a tech license - easy to get with no need to know morse code) which will give you access to better equipment, different frequencies and better range) or look into getting an FM radio setup on a commercial channel or something. We used commercial radios on our farm but I can't recall the steps you need to take to operate them, think you might need to apply for some sort of permit or something but you can look into it. There are many more options than CB but proper radio etiquette and compliance with proper fequencies and regs etc is very important! We do enjoy a lot of fredoms with radio usage in many areas and if the red tape gets you down - its important to know that in order to protect the priveledges we have on the airwaves and avoid MORE redtape is to play by the rules! Good luck and happy travels!
__________________
98 F150 4.6L V8 4x4 Extended cab
65 F250 352 V8 4x4 awaiting restoration someday...
  #7 (permalink)
Old 05-17-2008, 11:11 AM
Thanks.... I only use the truck/cb about two months out of the year. Seems like alot of hassle to be legal. But I understand your point as well. I had everything in my truck (cb/linear/ equipment ect...) done at a local cb shop. So I assume everything is good to go as far as "set up right". We run "Low" channels, so will it still interfere with others?
  #8 (permalink)
Old 05-18-2008, 08:16 AM
Dagre is starting off with a positive reputation.
Most every road driver in the trucking industry has a kicker(I am stretching the truth a little here).. If the FCC was all that worried about it they could write tickets and confiscate equipment all day today, tommorow, and for the next 5 years straight... That being said, if you want a 300 watt kicker. Just make sure you have somebody familiar with the setup to set the deadkey proper like. After you have your radio and linear setup right, then you need a proper antenna. A 300 dollar radio is only as good as your antenna. If you plan on spending 300 for the whole setup, then I would buy a 100 dollar antenna, 75 on the kicker, and 75 on the radio. The other 50 would be for the peak and tune, setting the deadkey for you @ approx 1.5 watts(depending on the linear), and setting your SWR's. You can get all this done at any CB shop. If you go ask the Ham guys they will give you the above responses.. They speak the truth above, but unless you want to put alot of "fire in the wire" you dont need to worry about it.
  #9 (permalink)
Old 05-18-2008, 08:50 AM
jjlogue3's Avatar
jjlogue3 has a good reputation on FTE.jjlogue3 has a good reputation on FTE.
Quote:
He didn't ask for help setting them up he just wanted to know about them. I think he got his question answered with out the help from an "extra class" licence holder.
__________________
Jeremy
1999 F150 4x4
3" Lift
DC-1 16x10 Wheels
33" BFG AT's
KANSAS CHAPTER
FTE Fraternity Of Blue Max
  #10 (permalink)
Old 05-18-2008, 09:42 AM
avator is starting off with a positive reputation.
Quote:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
