Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 04:55 PM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
Quick rocker shaft ?
Okay this is an easy question.For the life of me I can't remember if the drilled oil holes in the shafts point up or down.
  #2 (permalink)
Old 05-14-2008, 05:29 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is starting off with a positive reputation.
oh boy, Reagan came down with this stuff.. I may be as well LOL..
DOWN amigo
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #3 (permalink)
FFR428 is gaining momentum as a positive member of FTE.
Down..........
__________________
68 Mercury Cougar XR7, 200 6 cyl.
  #4 (permalink)
Old 05-14-2008, 05:36 PM
Okay Thats what I thought. But with them down I don't seem to get a lot of oil up top.The 390's I have built have been so good to me I have not had to build one in a while so i'm drawing some blanks.
  #5 (permalink)
Old 05-14-2008, 05:40 PM
Shafts or oil passages clogged? Proper clearance on the shafts and rockers? You do have the right necked down bolt in the head for the feed hole correct?
__________________
  #6 (permalink)
Old 05-14-2008, 05:56 PM
Redmanbob's Avatar
all the pressure is on the base side of the rockers due to the springs/lifters so there shouldn't be a real need for oil up top (if I'm reading that right) if oil isn't getting to the rocker shaft then wrong bolt or bad clearances? gallery somewhere bleeding off to much stuff ?
__________________
66 F100 352 V8
  #7 (permalink)
Old 05-14-2008, 06:12 PM
Also something Bill (Numbers Dummy) mentioned in another thread last week....Was the fact the earlier aluminum stands had a round bolt hole in them. They were prone to clogging and poor flow. Revised stands had the square bolt hole in em after that. If the bolts, clearances, stands etc... all checks out could be the feed from the block itself clogged or sludgy. Hows the oil pump itself? New, old?
__________________
  #8 (permalink)
Old 05-15-2008, 02:58 PM
There is a decent amount of oil when installed holes down, but none seems to hit the springs. I really can't remeber how much is supposed to hit the valves. Just don't want to break anything.
  #9 (permalink)
Old 05-15-2008, 06:59 PM
RapidRuss's Avatar
RapidRuss is starting off with a positive reputation.
Well dont worry about the seperation springs...If those are the springs your talking about...and the valve springs will normally swim in oil...
RJ
__________________
Blue Saphire 70 F250 390/C6 Limited Slip 3.73
Hedman Full length
Holley 750
BFGs With Turbine Wheel
With Some Damn BBF Morphing into something? Might be done by 2009? But will be wicked!!
  #10 (permalink)
Old 05-17-2008, 06:53 PM
I was worried about how much oil should hit the valve springs.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
