Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 04:47 PM
A Halcon is starting off with a positive reputation.
cel problem
hey all, forgive me if this has been posted, but I can't find answer, at least not for how it happened.
I have a 99 expy with the 5.4 triton. I went to get the oil changed, and while I was at it had the air filter changed. about 50 miles later, CEL came on.
I noticed when I hit on ramps and reach a speed of about 50 and the tac is still under 2000, it misfires. At first I thought it was in my head, but it started progressively getting worse. While idling at rest, it's fine.
I went to Autozone and got a code reading of PO171 and PO174.
came here and followed some advice and cleaned the MAF sensor. That didn't work, so I changed the MAF sensor. still didn't work. I have checked the hoses for vacuum leaks, all good.
Now, I know I can change the o2 sensors, but I don't buy it. doesn't make sense, because it was working fine, until I changed the airfilter and had the oil changed. Of course, I've seen freaky things happen before.
any help would be appreciated
thanks
A. Halcon
  #2 (permalink)
Old 05-14-2008, 05:01 PM
sbclemens is starting off with a positive reputation.
Check to see if all the electrical connections are in place on your air filter housing. Also check the PVC elbow located at the back of the intake to see if its cracked.
__________________
98 Expy XLT 4x4 5.4L
  #3 (permalink)
Old 05-14-2008, 07:37 PM
Yep! all fittings are good. I replaced the elbow and tubes last month and double checked them, again.
electrical connector to housing seems intact.
any other thoughts?
thanks for the help
  #4 (permalink)
Old 05-14-2008, 07:55 PM
alloro is starting off with a positive reputation.
You could've knocked something else loose in the area when you changed the air filter, so that's something to look into. But I'd be more inclined to think that the air intake duct from the air filter housing to the throttle body has a leak. Either it cracked or it's loose at one of it's ends. Any air that enters this duct after the MAF will cause a lean condition in both banks 1 & 2.
  #5 (permalink)
Old 05-14-2008, 08:18 PM
hmmm! didn't think of that. it actually makes sense. I'll look into it and report back
thanks
  #6 (permalink)
Old 05-15-2008, 10:22 PM
problem solved; albeit wasn't a crack in the housing and tubes after the MAF.
I finally had enough of the problem that I took it to the mechanic. according to him, 3 coils were shot. I felt it to be too coincidental, but honestly, my patience ran out and I had him replace them along with the spark plugs and wires.... $500, but whatever. small price to pay for peace of mind.
thanks for the help guys
  #7 (permalink)
Old 05-16-2008, 06:58 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Coils won't cause those fault codes....... They cause misfires.
Methinks you got taken.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #8 (permalink)
Old 05-16-2008, 09:39 AM
hmmm! Not that I'm trying to protect the integrity of the mechanic, but I did have major misfires.
When I went to autozone, like a dummy, I had the codes erased. I went to one mechanic and he said its better I wait until the codes come back. After another 100 miles of driving, they never came back. (yes I purposely drove around trying to get those codes back). So, not only did those codes not come back, but the misfiring was starting to get worse.
I stopped in at the mechanics yesterday afternoon and finally got it fixed.
coincidence that changing the air filter and coils go out? hmmm! I find it highly suspect. Did I get taken? I don't know considering the codes never came back after a hundred miles of driving, aimlessly
  #9 (permalink)
Old 05-16-2008, 09:57 AM
Quote:
Well, you didn't state that..
It's far more likely that the replacing of the air filter triggered the "lean" codes and that that particular problem has not been directly addressed (may come back).
Steve
__________________
  #10 (permalink)
Old 05-16-2008, 04:55 PM
Sorry if it wasn't clear
I did put this in the original post
Project, I do feel a little more confident about my decision, after reading your post, thanks
  #11 (permalink)
Old 05-16-2008, 07:15 PM
Maybe the Autozone guy didn't pull all the codes. The misfires may have been pending codes.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
