Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 04:28 PM
Rob.D is starting off with a positive reputation.
02 Exporer Rear Spring?
Well it's been raining problems for the last two months with my wifes 2002 Explorer 4.6 V8,4x4, 98,500miles. It all started last month with another wheel bearing then an IAC. Last week the drivers window quite working. I had her take it a local place, they forgot to order the part after 4 days so today she took it to the Ford dealership. They replaced the window switch and all is fine. She gives me a call and tells me she just picked it up and the service manager informed her that a rear spring was cracked and this is a common problem with 02's along with wheel bearings. He advised her that the vehicle would drop in the rear if the spring failed, duh! He also advised her that with the current mileage and inherint problems with the 02's we may want to look at a new vehicle!! This guy takes the cake!
The vehicle has been paid in full for about 2 years and I plan on her driving it a couple more years. I'm out of town working this week and have a couple questions.
1. Is the rear spring a coil-over shock and how hard are they to change? What brand?
2. If I'm doing the rear shocks might as well do the fronts. How bad are they to change? What brand?
3. I also intend to change plugs and wires, should I stay factory or is aftermarket fine?
4. Where is the best place buy or order all the above?
Thanks guys
4. What
__________________
NRA Endowment Life Member(Join Today!)
2006 F-350 6.0 PSD,XLT,CC,FX4,LB, Tow Command, Camper Package, Wet Okole Camo Covers, Upfitter Switches, High Idle Mod, Line-X, ARE Z Series Cap, Muffler Delete, Power Elbow, Fumoto Valve, Garmin Nuvi 350, Dieselsite Coolant Filtration, HFCM drain
2002 Explorer, 4.6L(V8) 98,000miles (wifes)
  #2 (permalink)
Old 05-15-2008, 09:05 AM
When I replace the broken spring should I also replace the other one at the same time?
__________________
  #3 (permalink)
Old 05-15-2008, 03:55 PM
CMOS is starting off with a positive reputation.
IIRC, the rear is a leaf spring style on the 02's, right?
If so, hell yes replace both the left and right. Replacing shocks is not difficult. I just did all 4 on my 2001 without any real problems. I like the Monroe Sensa-trac or the Monroe Reflex on these trucks. Get em from TheShockWarehouse.com.
Stay with Motorcraft plugs and wires for sure.
Good luck. The cost of these "repairs" is far less than a new vehicle. Well worth doing, IMO.
CMOS
__________________
2001 Sport-Trac, 2WD, 4.0, 5R55E Auto, 4.10 gearing
"Faith in Government defies both history and reason."
  #4 (permalink)
Old 05-15-2008, 06:18 PM
No, leaf springs. First year for the independent rear suspension I believe. Got home this evening and the dealer was correct one of the rear springs is rusted through. Planning on replacing springs and shocks on all 4 corners over memorial day weekend with some help from my step-dad. Any tips, help would be appreciated before I tackle this project.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
