Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 01:02 PM
HAMOK is starting off with a positive reputation.
rubber o-rings and biodiesel ?
hey guys first time poster here, I have been researching biodiesel for awhile and just stumbled upon an 84 f250 6.9 w/ats turbo kit and a dual range od for 400.00 dollars. so now im serious about it. do i have to change all of the rubber components in the fuel system i.e. the ip , the lines , etc.. ? i have been slowly putting together all of the parts to do a prossesor in a trailer with a co2 fire system. any input on this would be greatly appreciated.
thanks in advanced
Troy
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 07:28 PM
cookie88's Avatar
cookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to behold
Hello Troy. Welcome to FTE!!!
An 84 model may very well still have some natural rubber components, but I don't know for sure. Diesel rated low pressure line (sae30r7) isn't all that expensive so it wouldn't be too big of an issue to replace the supply and return lines. Chances are a $400 6.9 probably needs the injection pump and injectors rebuilt anyways, so that really shouldn't be an issue either.
Sounds to me like all the pieces are falling into place for you.
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck - AWM
96 Merc Grand Marquis (hers) mostly stock 4.6
68 Merc Montego completely stock s-code (275HP 2bbl) 390 - AWM
  #3 (permalink)
Old 05-14-2008, 07:56 PM
thanks cookie88 , the truck has 126,000 mi on it , the 4-speed reverse pivot bolt "fell out" so i picked it up cheap, do you know of anyone who sells a rebuild kit with the right seals ?
thanks
Troy
  #4 (permalink)
Old 05-15-2008, 08:28 AM
Phydeaux88's Avatar
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Hamok
Unfortunately the age of your truck will be a bit of a problem. Ford went to all vitron in about 1994 but prior to that there was a mix of vitron and rubber for several years.
First step would be talk to your local ford dealership parts store and see if they can tell you which parts are rubber then see if they have replacement vitron or similar substance parts. You can buy long tubes and hoses from other sources and probably some O-rings but gaskets and diaphragms will be part specific so will have to come from ford.
__________________
1996 F250 4X4 Crew Cab: Diablo Flip Chip, Powershot 2000, Hypermax exhaust turbo back, Tymar AIS, All the gauges, Bilstein Shocks, AirLift Super Duty bags on the rear
  #5 (permalink)
Old 05-15-2008, 11:41 AM
thanks phydeaux88 , i will start calling around , thanks for thew help guys.
Troy
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
