500 CID Lincoln Y-block for '53-'56 F100
Old 06-29-2013, 02:35 AM
drtrcrV-8's Avatar
drtrcrV-8
drtrcrV-8 is offline
The exhaust manifolds will all bolt-up to the heads, but have different outlets & shapes,& would require fabricating new exhaust pipes to fit the different manifolds & vehicle bodies, the 317 manifolds are for single exhaust w/crossover, the 368 are for rear exhaust,the '56-'57 Mk-II are different (all on their own),& the commercial (Ram-Horn) would also require custom fabrication
Old 06-29-2013, 08:31 AM
Necco-2's Avatar
Necco-2
Necco-2 is offline
Ok thanks for the info.
Old 08-23-2013, 03:25 AM
big job's Avatar
big job
big job is offline
Generally the Y block concept is the crank set way up in the block, that said, the MEL qualifys as well as super dutys. Unknown to most is MELs are a direct bolt up to FE FT engines.
Old 04-26-2014, 07:38 PM
richardge's Avatar
richardge
richardge is offline
Get a 477 cu in Ford truck engine, cubes are already there.
Richard
Badass56
04-17-2018 10:19 AM
Cobwebman
06-12-2016 12:36 AM
77 pickup
WTB - Parts & other
04-23-2016 12:23 AM
prostocktom
48
09-21-2014 02:34 PM
thx1138
17
12-29-2006 10:44 AM
Quick Reply: 500 CID Lincoln Y-block for '53-'56 F100
