500 CID Lincoln Y-block for '53-'56 F100 - Page 2 - Ford Truck Enthusiasts Forums
Old 06-29-2013, 03:35 AM
drtrcrV-8 drtrcrV-8 is offline
drtrcrV-8 is starting off with a positive reputation.
The exhaust manifolds will all bolt-up to the heads, but have different outlets & shapes,& would require fabricating new exhaust pipes to fit the different manifolds & vehicle bodies, the 317 manifolds are for single exhaust w/crossover, the 368 are for rear exhaust,the '56-'57 Mk-II are different (all on their own),& the commercial (Ram-Horn) would also require custom fabrication
Old 06-29-2013, 09:31 AM
Necco-2 Necco-2 is offline
Necco-2 is starting off with a positive reputation.
Ok thanks for the info.
Old 08-23-2013, 04:25 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
Generally the Y block concept is the crank set way up in the block, that said, the MEL qualifys as well as super dutys. Unknown to most is MELs are a direct bolt up to FE FT engines.
Old 04-26-2014, 08:38 PM
richardge richardge is offline
richardge is starting off with a positive reputation.
Get a 477 cu in Ford truck engine, cubes are already there.
Richard
Rocker Arm Shafts 77 pickup WTB - Parts & other 2 04-23-2016 01:23 AM
NEED 302/ 332 HD Y-Block Crank or INFO prostocktom Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 48 09-21-2014 03:34 PM
1955 Ford F800 Power Steering Set Up mint51 1961 - 1966 F-100 & Larger F-Series Trucks 0 08-03-2014 08:54 AM
A better (newer) 4 bbl for my Y-Block JeffLee Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 12 06-05-2014 07:34 AM
302 and 332 Y-Block captradiator Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 01-04-2006 06:55 PM
Tags
317, 368, aluminum, bearings, bee, block, camshaft, heads, inboard, lancaster, lincoln, magazine, main, ski, trojan, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
