Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 10:30 AM
gungho351 is starting off with a positive reputation.
Need some advice about installing cam
I've never put a cam in before. Just need some advice. Or is it one of those things that the machine shop should do. I haven't picked the block up yet as the machine shop isn't done with it yet.
__________________
2000 F350 XLT Supercab Longbox,7.3L powerstroke
4" skyjacker lift with 35x12.5
4" exaust, 6637 air filter, 6.0 IC, 80hp injectors, garret ball bearing turbo, duel HPOPs, Edge Evolution, ATS tranny
73 f250 2wd 390 motor
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 02:38 PM
MikeWire's Avatar
MikeWire is starting off with a positive reputation.
FWIU and have seen done, use lot's of lube be gentle, don't force it and be careful not to knick the bearings. I could use more innuendos, but I think you get it lol.
__________________
1975 F250 Highboy 4x4
Ranger XLT
390ci, 2bbl
4 spd, Manual
Dana 44-6CF/Dana 60
Resurrected from the dead.
Volkswagens too...
http://www.bigskyvw.com
  #3 (permalink)
Old 05-14-2008, 03:03 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is gaining momentum as a positive member of FTE.
Nothing a novice cant do with patience. White grease on the journals, engine assembly on the lobes. Really careful and with the block upside down you have access to help it stay ding free on the way. It's sharp!! Once in give it a twirl, if it binds at any point call the machinist (either his bearing installation is poor - unlikely as they usually check it, or your cam in bent - less likely but not impossible)
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #4 (permalink)
Old 05-15-2008, 07:17 PM
RapidRuss's Avatar
RapidRuss is starting off with a positive reputation.
Well if you have installed one before you can get by with just some long bolts mounted in the cam gear holes...If not a cam install tool for leverage is a great help....While I have never used white grease on the cam bearings....I do use a liberal amount of Break in lube on the journals..
RJ
__________________
Blue Saphire 70 F250 390/C6 Limited Slip 3.73
Hedman Full length
Holley 750
BFGs With Turbine Wheel
With Some Damn BBF Morphing into something? Might be done by 2009? But will be wicked!!
  #5 (permalink)
Old 05-19-2008, 05:30 PM
80broncoman is starting off with a positive reputation.
The grey moly paste is best from the cam lobes. Just about anything is better than air for the cam bearings and journals.
__________________
Real men don't wear Bowties
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
