Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 09:11 AM
excalibur3000 is starting off with a positive reputation.
Excursion Suspension Upgrades
Everyone,
I have been watching here for a little while, bought a 2001 X -V10 about a month ago. Mine has some wander - does not sound as bad as others, but not right either. So far, I have ordered new shocks (not on yet), installed RAS on the back, and installed U-code equivalent aftermarket springs on the front. I do not have a factory sway bar. I just finished the front springs last night - what a job, but also what an improvement! Test drive felt GOOD. My problem is that all four wheel wells are now pretty much level all at 40 1/2" +/- 1/4". However, it does not look level - it looks like the front is higher. My first though was to put on the rear taperd 250 blocks that Stewart has mentioned a number of times. I think that will put me where i need ot be height-wise, but am I creating a problem with leverage seeing as I still have my stock rear springs (albeit with the RAS)? I am hoping not to have to swap out the rears too at this point. Anyone else have any other bright ideas?
Thanks,
Casey
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 12:47 PM
Monsta's Avatar
Sit. Stay. Become a
Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.Monsta has a great reputation on FTE.
Can't you increase the RAS rate to raise the rear?
You should measure height off frame points since the wheel well opening front to rear are no at the same height on the body. That's why it looks "off" to you.
__________________
Ken
05V10
So many cats, so few recipes.
  #3 (permalink)
Old 05-14-2008, 08:15 PM
Ken,
I probably could ratchet up the RAS, but they give you a set procedure for adjusting it with an explicit warning to not exceed the specified tension. The frame isn't straight (flat) so how do you measure this way?
Casey
  #4 (permalink)
Old 05-14-2008, 10:22 PM
Monsta's Avatar
Sit. Stay. Become a
oh...that's right. Guess I was thinking for side-to-side comparisons.
__________________
Ken
05V10
  #5 (permalink)
Old 05-15-2008, 09:20 AM
Broken Wallet is starting off with a positive reputation.
I put a 6" Pro-Comp lift kit in my 2000 V-10 Ex and I have the same look it looks like it's sagging in the back like a loaded diaper. I going to put bigger springs. As far as measuring it use the pinch welds or body line.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
