Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 06:19 AM
sylvesterj01 is starting off with a positive reputation.
quits right after it fires up
i have a 98 f150 4 x 4, 5.4l engine, 150,000 miles.
driving home the other day it stalled on me all of a sudden without warning.
it had been running fine. a few days ago something came loose in the exhaust and has been pretty loud lately. also i can hear the fuel pump come
on when i turn the key but it runs only for a quick second ( i don't know how
long it should stay on at startup) i can fire up the truck but it quits immediatly. if i hold the gas all the way to the floor i can barely keep it
running but very rough. not enough to even try to move it any where.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 06:36 AM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
Welcome to the forum!
The rough idle sounds like a stuck Idle Air Control (IAC) valve. There have been a number of posts about it. Some clean them while others replace it.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 05-14-2008, 07:05 PM
78fordman's Avatar
78fordman is starting off with a positive reputation.
buy a fuel pressure gauge and see if it is within spec, 40 psi i think. if low i would go new pump and filter. Also when checking it see if it holds the fuel pressure, if it bleeds down rather quickly you may want to replace the fuel pressure regulator too.
__________________
2000 F-150 4WD Auto, 5.4, ex Cab
1970 f-100 2wd, 4 speed, 425hp 390
Proud To Be a High Plains Drifter
Tried true 'n blue
  #4 (permalink)
Old 05-14-2008, 07:15 PM
jimm66's Avatar
jimm66 is starting off with a positive reputation.
Jammed up fuel filter. When did you change it last? Welcome to FTE.
__________________
2002 F-150 XLT supercab FX4 5.4, true blue, Westin oval bars, lo-pro, piaa horns, rancho 5k's,
husky liner mud guards, trail-seal, sirius, fire extinguisher, mag-lite, tail-gate-easy-lift, bfg at ko's,
1998 taurus 24 valve, debadged, custom grill, pioneer 2600,
  #5 (permalink)
Old 05-16-2008, 02:22 AM
JJ98 is starting off with a positive reputation.
what if the cats come apart and pluged up the exhuast or a baffle in the muffler is lose and when start it it closes the exhaust off but iam not sure good luck
  #6 (permalink)
Old 05-16-2008, 09:27 AM
Joe Finn's Avatar
Joe Finn is starting off with a positive reputation.
Quote:
This is the most likely cause.
__________________
'97 F150 4x4 XLT 4.6L 3.55 LS Supercab
  #7 (permalink)
Old 05-16-2008, 10:07 AM
Spotty is starting off with a positive reputation.
A rough or low idle is classic IAC, but if you hold the pedal down a little it would run fine. If you hold the pedal down a little and start it will it run OK? If so I say IAC, if not something else is wrong. You say all was well before you heard an exhaust problem. Find the source of the exhaust leak and look in that area. Maybe somethimg plugged as others mentioned. Maybe a wire for one of the upstream O2 sensors is cut. As far as the fuel pump noise, that is standard on startup. Listen to most any other fuel injected vehicle, you will hear the same thing when you turn the key to run position. If it runs that bad it should toss a CEL, then you can pull codes. Good Luck, try to let us know what you find.
spotty...
__________________
98 Ford F-150.4.6.4x4. Extended Cab 8' Box
97 Mustang Gt, Black on Black, 100% stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
