power mirror question. - Page 2 - Ford Truck Enthusiasts Forums
Old 04-26-2012, 06:46 PM
tomjones1028 tomjones1028 is offline
tomjones1028 is starting off with a positive reputation.
To remove the switch all you need is "a flat blade screwdriver and some confidence" as another site put it. Use a sharper blade, at least 1/4" wide, and you should be fine. Also, I needed to go deeper than I first estimated before prying up. (Note: I have a 2002 F150...make sure you have the same switch in your model/year.)
I started losing some power mirror control capability about 18 months ago...completely gone about 8 months ago. Thanks to threads like this one, I figured the switch was the likely culprit, and thanks to the info above, I learned that WD40 might be used to rehab the switch.
I removed the switch, cleaned it, sprayed WD40 liberally on the top side, and exercised both the "joystick" and "lever" about 100 cycles in each direction...I now have 100% mirror control restored. I'll post an update if the switch fails anytime soon...
Many thanks!
Old 09-05-2013, 09:35 PM
reddogracing's Avatar
reddogracing reddogracing is offline
reddogracing is starting off with a positive reputation.
I know this is older, but no sense reposting on the same subject.
I did the clean on the 01 in my sig and it worked great.
HOWEVER
the 99 i just bought, is another story. Someone replace the pass mirror with non power, and it looks like they replaced the drivers mirrors as well, it is power. but the wire harness is differant.
anyway at the truck harness there are three wires coming out red, blue, yellow they run to a plug that has also a black wire that has been cut and goes to nothing.
one wire is hot which wires can i jump to test mirror and do you need the pax mirror for it to work correctly?
Swapping Door Mirrors to Power Fold Wrenchgear 2009 - 2014 F150 3 05-23-2015 12:20 PM
Who's right, me or Ford StanleyZ 6.7L Power Stroke Diesel 79 04-09-2015 07:08 AM
2011 F250 Mirror Help WillyD865 1999 to 2016 Super Duty 2 10-15-2012 08:41 AM
2003 Tow Mirrors on 1999 F-350 Miles07 1999 to 2016 Super Duty 9 04-16-2010 01:59 AM
99 F250 Towing Mirror Confusion??? subysouth 1999 to 2016 Super Duty 10 06-10-2008 06:59 PM
Tags
03, 97, attachment, cable, f150, ford, fuse, location, mirroe, mirror, mirrors, mustang, passenger, power, switch, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
