05-14-2008, 03:42 PM
Pretty sure the Cannister purge operates at 1500 RPM's or more, but if it does operate at idle, it could make a fluctation. I would disconnect & plug the purge line with your thumb & see if you can feel a vacuum. Do you have an intermittent sticky PCV ?
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 292,000 kms & going strong !
