Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 04:43 AM
Pablo-UA is starting off with a positive reputation.
ECM strategy qs.
Sometimes idle speed increases up to 750-800 rpm, i tried to unplug IAC, but idle speed sometimes increase. How ECM can do it w/o IAC? What for ECM does it?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 06:55 AM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
1. intermittent intake air leak
2. intermittent MAP or MAF sensor output
3. intermittent false signal from pwr steering switch or AC on switch
what's your O2 sensor V. reading doing during idle rpm increase periods?
  #3 (permalink)
Old 05-14-2008, 01:56 PM
Quote:
I will try to measure. ECM increases idle speed for 5-20 sec. only. May be canister purge solenoid does it
  #4 (permalink)
Old 05-14-2008, 02:28 PM
xlt4wd90 is starting off with a positive reputation.
Besides the air leaks, any false signal that causes the EEC to advance the timing will cause engine rpm to surge. That's easy enough to check with a timing light. You don't even have to find a real mark, just a reference point, and see if the timing changes when the engine surges.
Also, the EEC uses the IAC to bump up engine speed when running AC. If he's unplugged the IAC, that should no longer happen.
  #5 (permalink)
Old 05-14-2008, 03:42 PM
Aeroman59's Avatar
Aeroman59 is starting off with a positive reputation.
Pretty sure the Cannister purge operates at 1500 RPM's or more, but if it does operate at idle, it could make a fluctation. I would disconnect & plug the purge line with your thumb & see if you can feel a vacuum. Do you have an intermittent sticky PCV ?
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 292,000 kms & going strong !
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
