Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 01:32 AM
GONZO86 is starting off with a positive reputation.
Brakes work but peddle stays on the floor??
The Brakes work great but the peddle will stay all the way down, I pull up with my foot and all is good till the next time I need to stop.What can this be?thanksThis is on my 1978 f250 crew 4x4
  #2 (permalink)
Old 05-14-2008, 03:33 PM
is there a spring
is there a return spring on the brake pedal??like I said brakes work fine, fluid is good. press brakes, feels normal but pedal has no rebound..NO thoughts anyone???thanks
__________________
1978 f250 crew cab 4x4
  #3 (permalink)
Old 05-16-2008, 01:28 AM
bustech81 is starting off with a positive reputation.
can you hear air entering the booster when you step on the brakes? does this only happen with the truck running? sounds like possibly bad booster. disconnect vaccum line and re-try.
  #4 (permalink)
Old 05-21-2008, 12:34 PM
ynevada is starting off with a positive reputation.
could be a bad MC also. the piston can hang up in the bore slightly, causing it to drag, and the tiny internal spring isnt enough to push the pedal back up.
__________________
reaperoffroad
  #5 (permalink)
Old 05-21-2008, 02:33 PM
lsrx101 is gaining momentum as a positive member of FTE.
Quote:
On many dentsides there is a lever setup behind the brake booster that gets tight. The rod on the pedal is connected to the booster via this lever setup and when it gets dry and rusty, the pedal won't return.
It makes a good appalachian parking brake.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #6 (permalink)
Old 05-21-2008, 03:08 PM
ah, good point. the pin/pivet gets tight. check that first.
__________________
reaperoffroad
  #7 (permalink)
Old 05-21-2008, 08:04 PM
Quote:
The only way I knew was because I drove a 77 F-250 SC for 3 years like that and didn't know what was wrong. Many years later I found the cause on friends truck. It was a real head slap moment.
__________________
  #8 (permalink)
Old 05-24-2008, 02:55 PM
bossind's Avatar
bossind is starting off with a positive reputation.
Quote:
Really! Please explain why that would be. Never mind, if it was the booster it would be harder to push the peddle, he likley has air in the lines of a bad MC.
__________________
-Steve
96 Bronco, SAS, 4.88, 35s, Hydro Boost, 3" exhaust, 4 wheel Disc brakes, Sag PS Pump.
  #9 (permalink)
Old 05-24-2008, 05:34 PM
mark a. is gaining momentum as a positive member of FTE.
This is the linkage that gets froze up.
__________________
'79 F250 13" lift 42" Super Swampers
  #10 (permalink)
Old 05-24-2008, 08:39 PM
wow
Got out the wd-40 and sprayed the conections shown, also took off the master and cleaned the rod and sprayed a little wd on it too.works as good as a 30 year old truck should,thanks all for the help.R
__________________
  #11 (permalink)
Old 05-24-2008, 09:03 PM
Cool. I'm glad that worked. It only took me 10 years to figure it out.
WD-40 won't last once it evaporates though. You need to get a real lubricant back there. Even motor oil in a squirt can would be ok.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
