Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-14-2008, 01:04 AM
BeufordTJustice01 is starting off with a positive reputation.
Best way to get better Mileage??
Got an 89 F250, 351w, auto, getting 9-11 mpg. Anybody know a reliable way to increase this even a little bit?
  #2 (permalink)
Old 05-14-2008, 05:13 AM
351slug is gaining momentum as a positive member of FTE.
Tune it up, Bump timing up a little, drive easy. Im getting 16 MPG on the hyway 351W 4x4 W/35 BFGs.
  #3 (permalink)
Old 05-14-2008, 06:27 AM
wdstang is starting off with a positive reputation.
buy a honda!!!lol
  #4 (permalink)
Old 05-14-2008, 07:02 AM
bluesman2333's Avatar
bluesman2333 is starting off with a positive reputation.
The best mileage enhancement is sane driving. Other things like a properly maintained engine, good tires and keeping weight off help too of course.
  #5 (permalink)
Old 05-14-2008, 10:06 AM
kuzycc is starting off with a positive reputation.
When I bought mine, it was getting about 9mpg. I did a complete tune up on it (92K with the origanal plugs, wires, cap and rotor). And it did nothing. I put a cold air intake on it and ran strait pipes, it did nothing. I just put knew tires on it, and again, nothing. But, thats a ford 460 for ya. I've got all the power I'd ever need though.
  #6 (permalink)
Old 05-14-2008, 12:55 PM
phoneman91 is starting off with a positive reputation.
If your truck has over 50k miles on it and it still has the original oxygen sensor--replace the oxygen sensor.
I did on my 105k 1992 F150 and got an immediate~ 1 MPG increase--with better throttle response.
__________________
92 F150 XLT 4x4 regular cab/short box.5.0 V8,5sp trans ,108k miles-- on synthetic oil. Trailering/Handling option(stabilizer bars front /rear and quad shocks).Factory skid plates,manual hubs, manual transfercase, Super Cooling.4.09/4.10LS.31'' tires. 20.3 MPG @ 60 MPH.4350 lbs with full tank of gas!!
  #7 (permalink)
Old 05-14-2008, 02:33 PM
Virto is gaining momentum as a positive member of FTE.
Remember first and foremost, these things were not built with fuel economy in mind.
They're as aerodynamic as a brick, turned sideways.
If you do a bunch of highway, keep the speed under 65. That makes a BIG difference as wind resistance increases with velocity. If anyone thinks that means it'll take to long to get where you're going, then don't complain about gas. I can't tell you how many people I listen to in th office every day crying that thier new car doesn't get 30 mpg like it should, only to find out they're doing 80 on the expressway.
If you do a lot of city, use smooth, slow starts. Don't go half throttle at every light. You might make the people behind you crabby, but what are they going to do, ram you? Avoid sudden stops if you can, anticipate lights and signs and coast up to them if it's safe. You don't have to have your foot on the gas right up until the second you need to hit the brakes.
Make sure you have any extra weight out of the truck. Keep the tires inflated properly, keep up on general maintenence.
Depending on the rear end you have, numbers can go up or down compared to other peoples'. If you can squeak out 15hwy I wouldn't expect anything more.
__________________
Join us in fighting disease! Fold for FTE team 53449!
Quote:
Originally Posted by Silver Streak View Post
You're having problems because some butthole put the wrong one on your truck.
1990 Ford F-150 XLT Lariat Supercab - 5.0/E4OD - Off to that big wreckers in the sky...*sniff*
1993 Ford F-150 XLT Supercab - 5.0/AOD - 3.55
  #8 (permalink)
Old 05-14-2008, 05:28 PM
Jermafenser's Avatar
Jermafenser is starting off with a positive reputation.
1) Unload all the junk in the bed and the cab
2) Inflate the tires to 5 psi over the factory's recommended PSI
3) Convert all fluids to 100% synthetic
4) Ensure the engine is operating at its best temperature
5) New Spark, plugs, wires, distributor cap & rotor, coil, set ignition timing
6) Accelerate SLOWLY
7) Do not go above 65 for any reason at all
8) Install a vacuum gauge
9) Tune carburetor for economy
10) DEDICATED EXPIREMENTING 24/7!
__________________
You can call me "Jerm" or "Jer" ...or just call me Chad!
1997 F350 XL 4wd SRW; 351W EFI & E40D
1994 Explorer XLT; 5spd
1979 F250
  #9 (permalink)
Old 05-14-2008, 05:45 PM
quicklook2's Avatar
quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.
most of these trucks have efi, no carb.
not too sure about the 5 psi over recommended psi.
__________________
"The essence of knowledge is, having it, to apply it; not having it, to confess your ignorance." ~Confucius
  #10 (permalink)
Old 05-14-2008, 05:48 PM
Overinflating tires cause premature wear and breaking problems. The mileage does increase marginally though. Having high profile tires properly inflated is the best scenario.
__________________
1993 F150 302 somesortofautomatic. F350 front springs, bed liner, tool box, ugly tail gate. One thing you can say about a F series truck is it's as aerodynamic as a brick, turned sideways.
  #11 (permalink)
Old 05-16-2008, 10:39 PM
Thanks for the input!!
Many great ideas, I think I'm already doing most of them. I know how much sane driving can do. When I used to raise more hell than I do now my license got revoked for 3 years, kept driving (like grandma though, slow and easy) didn't pick up on the difference then. But when I got my license back I went back to tearing up the streets and almost immediately noticed how much gas I burned up driving fast, I think it cut my mileage in half.
Hey Jermafenser, what will installing a vacuum gauge do? Does synthetic really make a difference?
I think Virto said it best,
"Remember first and foremost, these things were not built with fuel economy in mind.
They're as aerodynamic as a brick, turned sideways. "
Thanks again guys
  #12 (permalink)
Old 05-17-2008, 06:23 AM
You can use the vac gage to keep your acceleration in check. When it dips down, you are drinking gas. When it is high, you are sipping gas. Synthetic oil really does help.
__________________
  #13 (permalink)
Old 05-17-2008, 09:01 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
If you ask me 9-11 mpg is still low, that truck should be able to do better than that strictly city driving, and much better strictly highway. What gearing does it have? And have you pulled the codes recently?
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #14 (permalink)
Old 05-19-2008, 11:38 AM
JasonI's Avatar
JasonI is starting off with a positive reputation.
My 89 gets 11mpg on the highway with both tanks full.
  #15 (permalink)
Old 05-19-2008, 02:43 PM
RJBain's Avatar
RJBain is starting off with a positive reputation.
On my 92 F-150 4X4 with a 302 and a 5 speed manual tranmission, I installed a set of March underdrive pulleys and my milage went from 11 mpg to 13. This was hand caculated over 3 tanks of fuel before the install and 5 tanks of fuel after the install. This was all local driving with no highway driving. I purchased this pulley set used which were only installed for a short period of time. The powder coating only showed slight wear. If I were to do it again, I would buy the steel pulleys instead of the aluminum ones. The waterpump pulley has worn down a good amount.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
