Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 08-28-2008, 07:12 PM
HighProCam's Avatar
HighProCam HighProCam is offline
HighProCam is starting off with a positive reputation.
My 78 F250 is a long bed with 2 tanks, which put the shackle bracket right beside the rear tank, just a little different from CaptainP4's pics where the bracket is at the back of the tank.
I also added the 0-rate offset leaf (block) that UTfball used when he did the swap from Offroad Design. The shackle flip rotates the leaf springs down and a little forward so the 0-rate leaf moves the axle back an inch keeping the axle centered, however not mandatory to do the flip.
The bolts that come with the sky kit are a little larger than the rivets so you'll have to enlarge all the holes slightly to a 1/2" bit.
I'll add some pics if I have some that show something different than already posted.
__________________
78 F250 - I traded a Jeep for my Truck......
http://i30.tinypic.com/2ytuqg1.jpg http://i30.tinypic.com/iv8ks5.jpg http://i26.tinypic.com/20iwhsp.jpg
  #32 (permalink)
Old 11-02-2008, 04:34 AM
Ford400Man's Avatar
Ford400Man Ford400Man is offline
Ford400Man is starting off with a positive reputation.
Quote:
Originally Posted by littleme13 View Post
nice writeup, direct and too the point.
just wanted to add for the newbies that this mod will lower your weight capacity if you haul heavy loads.
So, no more bales of hay and a fat chick in the back no more??
  #33 (permalink)
Old 11-02-2008, 10:16 AM
Truckin4life Truckin4life is offline
Truckin4life has a great reputation on FTE. Truckin4life has a great reputation on FTE. Truckin4life has a great reputation on FTE. Truckin4life has a great reputation on FTE.
Atleast not at the same time.... Just dont throw a ton of hay in the back, also not gunna be able to tow as much.....
__________________
Don
I like bacon.
Quote:
Originally Posted by captain p4 View Post
chuckstrucks brings the lols and make cheeto look like a genius.
  #34 (permalink)
Old 11-03-2008, 12:46 PM
77fordf-150 77fordf-150 is offline
77fordf-150 is starting off with a positive reputation.
Truckin4life. Look up ruffstuff products, they came out with a shackleflip that blows the sky one out of the water.
  #35 (permalink)
Old 11-03-2008, 04:05 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
I have heard the rumors about limited payload capacities, and I have run a shackle flip for years, and I still tow as much (actually more) than I ever have, and have never had a problem with this design.
I do not see anything that supports the limited capacity theory. Chnaces are that if the vehicle is going to be towing extreme loads, then the shackle flip modification os probably not the right mod.
As far as the stuff from RS, it is limited by shackle length, which is what makes the shackle flip that much more advantageous. The longer shackle will provide greater spring movement, and that means more articulation, and travel. Running short shackles and making the hanger just that much lower, just adds lift and thats all. Longer shackles is where it is at.
Now, side loads become a greater problem, and this might be where the limited strength theory was ciltivated, but this could be a problem with a tension design shackle as well.
Compression style shackles will not limit capacities, to the point were one might not consider the upgrade.
Tags
f150 , flip , ford , manufacturing , shackle , sky
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
