Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 09:24 PM
sticks25's Avatar
sticks25 is starting off with a positive reputation.
U joints or rear end going bad??? hard clunk
i have a clunk when accelerating and breaking. it sounds like u joints to me so i got under there and checked to see if there was any play in the drive shaft. i didnt see any but i did notice that when i spun the drive shaft (trans in neutral, wheels on the ground), that the yoke in the rear end would spin almost or about 1/8th of a revolution before it would stop. it seems a little more than normal to me. there was no measurable play in the yoke that i could feel. any ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-14-2008, 01:42 PM
aurgathor is gaining momentum as a positive member of FTE.
Clean and grease the yoke with CV lube. That *might* fix it.
  #3 (permalink)
Old 05-14-2008, 06:09 PM
twisted limb is starting off with a positive reputation.
A few years ago my 93' would clunk about three times when slowing down or pulling out.Turns out the slip joint needed greased and that took away my clunk then.This past year I started to get a whine and a hard clunk(much worse than slip joint clunk) in rear end and turns out carrier bearing in rear end was shot.Had all bearings and axle bearings replaced.Usually you will get bad vibration from u-joints from my experience.Take it to a rear end shop before you desytroy your gears, I'm glad I did.I only waited a few days before doing so.
  #4 (permalink)
Old 05-14-2008, 10:07 PM
sticks25's Avatar
ok, the slip yoke thing seems to be pretty common for clunking so i am going to try that first. there is no noise whatsoever but i have decided to park it until i solve this problem.
  #5 (permalink)
Old 05-15-2008, 02:27 PM
"There is no noise whatsoever"?I'm confused, you said you have a clunk?
  #6 (permalink)
Old 05-15-2008, 02:37 PM
sticks25's Avatar
im sorry i should have been more clear on that. there is no noise like howling, whining or grinding at any speed. just the initial clunk which i can feel and hear.
  #7 (permalink)
Old 05-16-2008, 10:30 PM
cajunland is starting off with a positive reputation.
does it feel like its under your feet? Check your radius arm bushings. When they get worn the radius arm moves up and down (during braking and accelerating) in the bracket. It will eventually wobble out the bracket (causing the clunking to happen more).
__________________
Tim
'93 Bronco - 302; E4OD; 4in ProComp, 35" Rem. Mud Brute
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
