Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 08:15 PM
jrlec1020 is starting off with a positive reputation.
What a 71 Ranger XLT came with back then?
I'm thinking of buying a 71 Ranger XLT. It has a 360 and manual tranny. The pics the guy has up shows a column shifter....did the 71's still have column shifters and if so what speeds did the manual trannys have in 71, 3 and 4 speed or just 3? Also would the Ranger XLT automatically have power steering and brakes? It has stock air conditioning. It's real clean and looks like no rust at all. You could eat off the engine bay it's so clean. He' wants a little above 5k for it, the mileage says around 70k on the truck it self and motor was rebuilt about 12k ago.
Like I said, it looks clean and straight, I'd just like to know what some options would have been found on the 71 and what options the Ranger XLT package put on it. Thanks.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 09:54 PM
I just found out it has manual steering and manual brakes. It has three on the tree maunual tranny.
  #3 (permalink)
Old 05-14-2008, 07:41 AM
limegoldf100 is starting off with a positive reputation.
The Ranger XLT package was mostly dressup - bright trim around windshield, back window, wheel openings. Had wide molding down the bumpside with woodgrain insert and a woodgrain tailgate panel. The seat, door trim, and headliner were upgraded.
Mechanically, they were like the other series, with two 6-cyl and three V-8s available, with (as your truck) a 3-speed manual on the column, 3-spd auto column, or 4-speed manual, floor shift.
__________________
71 Explorer 351W/C4
72 Sport Custom 302/C4
  #4 (permalink)
Old 05-15-2008, 07:26 AM
Paddy1998 is starting off with a positive reputation.
Red face A/C & trim
THe A/C is a dealer add-on. If you want you can verify the trim package by using comparing it with those offered specifically for the Ranger XLT 1970+ in the Dennis Carpenter or LMC Truck Catalog. Also there should be carpet and a headliner, this in addition to what limegold described.
Also this is the first time I've come across a 360 w 3sp on the column. Previously I've only seen 3 on the tree with a 6 cyl. Decode the VIN to make sure that it hasn't been monkeyed with.
1970 F-100 Ranger XLT
360, Borg-Warner T18 4sp
  #5 (permalink)
Old 05-15-2008, 07:55 AM
I bought a 71 Ranger XLT a few years ago for parts. It had a 360 with 3-speed on the column and factory-installed air conditioner.
__________________
71 Explorer 351W/C4
  #6 (permalink)
Old 05-21-2008, 06:39 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Quote:
my 1972 F-250 Explorer had factory air as well
Like what is pictured at the bottom right of this brochure.
http://www.ford-trucks.com/user_gall...=98777&width=0
  #7 (permalink)
Old 06-06-2008, 01:45 AM
swcash is starting off with a positive reputation.
And I would bet that the 70k is more like 170k miles. Those engines usually didn't need a rebuild at 50 + k miles. My best friend had 250k on his 69 and it was never apart and still running strong.
My 70 390 has 100k and runs like a new one with only the changeout of the timing gear at 100k. Both these engines are Southern California though.
I guess it all depends on the climate that it has been in. Cold starts can wear them out quick.
Squido
  #8 (permalink)
Old 06-06-2008, 04:53 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
There were two different air conditioners offered for these trucks.
The deluxe factory installed unit, and the economy dealer installed unit.
That's the "economy air" conditioner pictured in that brochure.
The deluxe air unit features 'wood' grained inserts, and a glove box.
The deluxe air uses a combo heater A/C plenum chamber. This unit was so large that the glove box liner had to be removed so the unit would fit behind the dash.
So the new glove box is part of the air conditioner head unit which bolts to and follows the contour of the dash...all the way across.
The deluxe unit runs all the way across the bottom of the dash with one register on the left side, then a "wood" grained insert underneath the column followed by another register.
The controls come next with another register above them (the unit is staggered at this point) then the glove box, and another wood grained panel followed by one of two things.
The 1968/69 units have a fourth register in line with the third, the 1970/72 units have a large register on the right side.
1964/72 Ford Truck Parts Catalog
Illustrations: Deluxe A/C: Section 195, Page 18 / Economy A/C: Section 195, Page 19.
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
