Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Exhaust Systems
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 07:46 PM
Epd444's Avatar
Epd444 is starting off with a positive reputation.
Covering up stacks hole
Any body got any suggestions on a good, decent way to cover up a hole in the bad after stacks were removed?? Do they make a tool box that drops that rests on the bed flat??
__________________
1997 F350 7.3 Reg Cab 4x4
61k E4OD 4.10LS
6'' Skyjacker
38'' TSL's on Mickey Thompson Classic II's
3" downpipe
5" Stacks
TW 6 pos chip
Gauges (boost, pyro, tranny)
AFE stage 2 intake
FOR SALE:
4'' Skyjacker lift off 97 F350
PM for details
  #2 (permalink)
Old 05-14-2008, 09:12 AM
Sycostang67's Avatar
Sycostang67 is gaining momentum as a positive member of FTE.Sycostang67 is gaining momentum as a positive member of FTE.
I dont know who makes them, but I have seen truck tool boxes that fit in between the rails and sit on the floor. I would just check some of the more popular brands like delta, husky etc. as they usually have the dimensions listed with the tool box. Then measure the space you need to fill to find what works.
__________________
1985 F-250HD XLT Lariat Supercab 4X4 460/5spd with a body swap.
2000 Mustang 3.8/AT
1979 Capri 302/5spd
1967 Mustang 351W/4spd
  #3 (permalink)
Old 05-14-2008, 04:49 PM
Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.
well if you dont want the tool box... and didnt save the cut outs... go to a junk yard... find a bed similar to yours... preferably trashed, and cut out 2 circles to cover up the holes... weld them in from the bottom... going around spot welding as not to warp the metal to much... Should work fine...
__________________
Don
Stg's Minions: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04 View Post
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
  #4 (permalink)
Old 05-14-2008, 04:57 PM
RDJ184's Avatar
RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.
our cut the cut outs to fit the hole and weld in slowly.... patience so you dont warp.... skip back and forth between the 2
__________________
JOIN NEW MEXICO CHAPTER HERE!
RANDY 06 6.0 4X4
  #5 (permalink)
Old 05-14-2008, 05:24 PM
thats what i actually ment, but do the welding on the bottom so you dont see the beads on the top....
__________________
Don
  #6 (permalink)
Old 05-15-2008, 09:27 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
And or grind any welds down flush. Then you can paint over it with primer. Repeat painting it and sanding it till it looks right, then paint it with the correct color.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDry filter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
