Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 07:31 PM
995.4SD is starting off with a positive reputation.
5.4 running like poo
ok, so last weekend my truck started running like it was miss-firing, but no check engine light. tookk apart the intake and found a lot of engine oil. I am running a k&n air filter but it had been a long time since i cleaned the filter so i knew it wasn't filter oil, plus it wasn't red. so i cleaned all of the oil out, and sprayed the MAF and IAT with elect. cleaner...all was well for a few days until today when it started acting up again. the best way to describe it would be a chug, especially at low rpm. my guess is the oil is messing with the sensors, but i don't know how or why there is so much oil getting into the intake. the pcv valve is new and working fine. what would happen if i disconnect these hoses and the plug the holes in the intake tube?
thanks for the help
  #2 (permalink)
Old 05-13-2008, 09:10 PM
italianstallion is starting off with a positive reputation.
How many miles? Can you see blow -by coming out of the valve cover when you pull the pvc ?
  #3 (permalink)
Old 05-13-2008, 11:20 PM
180K miles. i can see blow by if its warm, no more than if i were to take off the oil cap. another person suggested the coil on plugs, he said his truck had the same symptoms and he replaced the plugs and COPs and problem solved. but at about 50 bucks a pop i would hate to buy 8 and only need one. but without a mis-fire when i read the codes how could i tell which one is bad? only thing i can think of is buy one and swap it around til it runs good...any other ideas?
  #4 (permalink)
Old 05-14-2008, 08:37 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Have you tried a new PCV valve??
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 05-28-2008, 09:25 PM
thompson_08243 is starting off with a positive reputation.
Exclamation
yea my truck just started doing the same symptons, chugging at low rpms, and my ABS lghts flashes though and also my speedo goes nuts.... if any one has any advice please help!!!!
i have to tow in a few days from NJ to NY, is it ok????
  #6 (permalink)
Old 05-29-2008, 03:46 PM
wtroger is starting off with a positive reputation.
Replace the vss sensor that is bolted to the top of the rear end. Pretty common problem just a few bucks at most part stores
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
