Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 07:03 PM
rcslineman is starting off with a positive reputation.
What causes the idle control valve to rev up the engine?
My '96 f150 302 revs up all the time (2k) and I cannot afford wasting this high dollar gas. Unplug the ICV and it idles fine. Looking like it may be the MAF sensor, but not sure. Gimme me somethin smart guys.
  #2 (permalink)
Old 05-14-2008, 08:09 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
If in fact the IAC is opening and allowing the motor to rev high, it's because the computer is getting faulty info from it's sensors and it can't control the motor. You would have some codes stored if this is the case. If you don't have codes stored you probably have a large air leak past a gasket or through a vacuum line.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #3 (permalink)
Old 05-15-2008, 03:54 PM
IcemanV8 is starting off with a positive reputation.
That's exactly what my 86 does, and codes show out of range TPS. Except mine idles high with the plugged in (1500RPM sometimes, and sometimes 2000RPM), but if I unplug the TPS, I idle lower at the cost of running way too rich (fuel in oil)/loss of power/unresponsiveness. I just leave it in most of the time to avoid fuel in oil.
Check your idle screw, too. If you unplug the IAC and it runs FINE, it sounds like the idle is set too high. It supposed to barely idle (500RPM or so) with it unplugged, so try adjusting that, first.
__________________
1986 Ford F-150 4x4 5.0 EFI
XLT Lariat
NP435/NP208/9" 3.50 axle
Road Warrior bumper, Leaf Spring Overloads
  #4 (permalink)
Old 06-20-2008, 04:42 PM
Finally fixed it, the TPS was my entire problem. Thanks for the lead Iceman.
  #5 (permalink)
Old 06-20-2008, 04:53 PM
Thanks for the update. I can update saying I fixed mine a few weeks ago, also, and it was the TPS. Nice being able to idle again, isn't it? That 2k RPM stuff was killing my mpg.
__________________
XLT Lariat
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
