Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-03-2003, 07:45 PM
interceptor1 interceptor1 is offline
Garage is empty, add now
interceptor1 is starting off with a positive reputation.
Post 292 timing problems
I need help!
I'm having problems getting a newly rebuilt 292 started. Fuel and spark delivery are OK. It has to be timing related. I'm pretty sure the firing order is 15486372.(?) We put number 1 (front on passenger side?) at TDC, aligned the middle line on the crank pulley with the timing pointer, and pointed the rotor at the number 1 plug wire.
Nothing but a few backfires.
What am I doing wrong?
Any thoughts would be greatly appreciated!
  #2 (permalink)
Old 01-03-2003, 11:07 PM
rayray2k22002 rayray2k22002 is offline
rayray2k22002 is starting off with a positive reputation.
292 timing problems
check your point gap.... should be around......018 or .019
firing order is correct.....just double check the order on the cap!!!
  #3 (permalink)
Old 01-04-2003, 12:08 PM
2speed 2speed is offline
2speed is starting off with a positive reputation.
292 timing problems
Are you sure you don't have it 180 degrees out? Make sure that the #1 cylinder is on the compression stroke. When you bring it up to TDC put you thumb over the spark plug hole and make sure it's blowing out around your thumb.
  #4 (permalink)
Old 01-04-2003, 12:10 PM
pcmenten pcmenten is offline
pcmenten is starting off with a positive reputation.
292 timing problems
Are you sure that you have the number one cylinder at TDC of the compression stroke?
Make sure you have a good ground between the engine, chassis, and battery (three points).
With a points distributor you can static time the engine.
You can use Ether to help get the engine started.
__________________
Best regards,
Paul Menten
  #5 (permalink)
Old 01-04-2003, 06:17 PM
red56flatty red56flatty is offline
red56flatty is starting off with a positive reputation.
292 timing problems
I ran into this same problem when I rebuilt my 272 for my '56. What I did wrong had to do with the timing chain. I aligned the dots up on the crank and cam timing gears, like a windsor series, instead of counting the number of pins on the chain. I had the chain on backwards so I did not see the two identifying marks on the chain. My Ford manual says there needs to be 12 pins between the two dots. I was fortunate in that the pistons didn't interfere with the valves.
Hopefully this helps!
  #6 (permalink)
Old 01-05-2003, 02:00 PM
After getting some good ideas...I have a stupid question.
Which way does the crank rotate when viewed from pulley end?
This is a marine engine...It just hit me that it may be opposite rotation.
  #7 (permalink)
Old 01-07-2003, 04:48 PM
phjbbu phjbbu is offline
phjbbu is starting off with a positive reputation.
292 timing problems
__________________
Paul
  #8 (permalink)
Old 01-07-2003, 07:01 PM
2samoyed 2samoyed is offline
2samoyed is starting off with a positive reputation.
Reverse rotation engines run counter clockwise. Reverse rotation interceptor marine engines use a set of timing gears instead of a timing chain. Try this website.It has a manual for a 272 interceptor. http://personal.nbnet.nb.ca/khan/jetsite/intrcept.htm
  #9 (permalink)
Old 10-11-2006, 07:17 PM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a good reputation on FTE.WALFORD'S 56 has a good reputation on FTE.
I too have a similiar problem.I installed new everything on my 272/292 yblock 2 barrel.When I cranked it over it backfired some and then starter would jump out.--now I have to put distributor in but not sure of if I'm in the right gear tooth.--so now do I have to find tdc and put plugs back in and cap on and --oh yea--if firing order is 15486372--but where do you start on the cap for no.1? thanks--
  #10 (permalink)
Old 10-11-2006, 09:45 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Your cap should be marked with the number "1" if you look closely. As you engage the distributor gear on insertion, you will see the rotor move, so you need to offset a bit prior to insertion to get it to end up pointing at number one. Dont do the dist until you have determined the number one cylinder is close to TDC compression stroke. TDC should occur when your timing mark and pointer are at zero. I think the old posts above cover TDC.
The crankshaft rotates clockwise. Distributor counterclockwise. If priming oil pump with tool and drill before distributor installation, be sure to set drill for counterclockwise action.
__________________
Mike Southern Oregon
1946 1/2 ton with Y-block, '62 Mercury Meteor S-33, '55 Ford Country Sedan wagon, '64 Falcon Futura, '90 Ranger 4WD, '54 Ford model 600 tractor
  #11 (permalink)
Old 10-12-2006, 01:22 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 is gaining momentum as a positive member of FTE.
If the above suggestions don't work,
You may have to remove the timing cover and ENSURE that the timing marks are correct!
(alternatively you can ask the person who assembled it how he/she assembled the timing set........ask them to TELL you how they did it don't ask IF they did the 3 o'clock method)
http://www.ford-y-block.com/assemblyerrors.htm
The timing marks on the crank and cam sprocket MUST be at "3 o'clock" not opposing each other at 6 and 12 o'clock respectively (some mechanics confuse the Y-block with "other" engines).
Regards,
Rick
__________________
1955 F-600/292Y/E4OD // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!!
1947 Stinson 108-2 Station Wagon, Franklin 6A-335B
1987 Four Winns 211 Liberator, 1997 Mercruiser 454/Bravo III
(RESISTANCE IS FUTILE) 73 de Rick
  #12 (permalink)
Old 10-12-2006, 02:54 PM
THANKS everybody--I am almost ready to start again-but the winter weather just hit today and I am putting everything in for winter--sucks---and then back in the barn for distributor 1o1.thanks
  #13 (permalink)
Old 10-21-2006, 06:21 AM
f700's Avatar
f700 f700 is offline
f700 is starting off with a positive reputation.
292 timing
i bet its 180 out or wrong tooth at the distributor
__________________
F700
  #14 (permalink)
Old 10-21-2006, 10:42 AM
F700-I am starting to believe this is true.I have done everything else--I need a mechanic--ha ha!!!I guess I will try it 1 more time.thanks
  #15 (permalink)
Old 10-21-2006, 01:02 PM
f700's Avatar
292 timing
good luck take your time when you do it
__________________
F700
Tags
292, 312, block, enginetiming, f700, firing, ford, gap, gear, ignition, order, points, problems, time, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
