Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 05:44 PM
Bigtony4 is starting off with a positive reputation.
Towing in overdrive
Has anyone tried towing in overdrive on the highway? I know the constant shifting in and out of overdrive is not good for the trans, but if the truck stays in OD while driving on the highway will it cause any damage to the trans?
  #2 (permalink)
Old 05-13-2008, 07:17 PM
MBBFord's Avatar
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
I've done it several times with a 7,000 lb camper.
As long as it is on flat ground at a steady speed, it holds OD fine.
Get into the slightest hills or try and accelerate, it will shift down.
For towing at lower speeds, the truck feels to shift differently with OD off, so I usually do that, and when I get to hwy speeds I engage OD.
__________________
Matt
STGs Minions - Special Forces/Mud Division
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #3 (permalink)
Old 05-13-2008, 07:31 PM
4DOORSR is starting off with a positive reputation.
^I do the same. Anywhere over 110km/hr and I'm in overdrive. Helps drop oil temperature. If you tow alot I've got to recommend the Edge. I can monitor engine oil and transmission temps while keeping an eye on engine load when the tunes are cranked!
__________________
07 F550 V10-Daily driver
04 F150 Lariat SCAB 4x4. Magnaflow SIDO/2.5"AS/ 305/65/18 BFG's/Westin Bull bar/PIAA SMR Series/Volant CAI/EDGE
93 Altima- SR20DET-Many mods.
  #4 (permalink)
Old 05-13-2008, 08:31 PM
MohaveMike is starting off with a positive reputation.
A wise man once said, A tranmission is more expensive that a little extra fuel. The only time I let the trans into od while towing is when I am going down hill, in both the F150 and 250.
  #5 (permalink)
Old 05-13-2008, 10:33 PM
XolieX's Avatar
XolieX is starting off with a positive reputation.
just a month ago i towed with my 150 5.4 screw, well with or without the overdrive, i got the same MPG (12.5-13.5mpg). it seemed weird but it was actually happening. i guess with the OD the engine speed may lower but the throttle is more open.
oh yeah, of course this was with a stock tune 5.4.
__________________
  #6 (permalink)
Old 05-13-2008, 10:49 PM
thewheelman's Avatar
thewheelman is starting off with a positive reputation.
I've had 3 conversion vans: 2 150's and 1 250 and have pulled a 28 and 30 ft. camper with them--all in od. From KY to FL, from KY to Gatlinburg, from KY to NY & DC, all over southern IN and no problems. Now, only the 250 would hold cruise--even in the flat lands of FL. But I experienced not a single transmission problem. I thought you were supposed to tow in od, that the bowtie boys weren't.....
  #7 (permalink)
Old 05-13-2008, 10:52 PM
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
You can do it for sure just be cautious good to get tranny temp guages and keep it out of od if its hunting a lot
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
  #8 (permalink)
Old 05-14-2008, 01:55 AM
tylus's Avatar
tylus is starting off with a positive reputation.
towed ^^^ through Washington state for about 200 miles. Kept it in O/D until I hit the hills up/down to prevent the transmission from constant downshifting. in the flat and sorta hill areas, the transmission held 60-65 mph just fine with O/D. got 12 mpg on that tank
btw, I agree with Dustin1690...use O/D judiciously...but as soon as it starts to hunt/downshift, lock out O/D. it isn't worth the risk in those cases
__________________
Previous Fords:
1984 F-150 (302 V-8), 1989 F-150 (300 I-6), 1993 Bronco (302 V-8), 1994 F-150 (300 I-6)
1994 F-150 (302 V-8), 1995 Mustang (3.8 V-6), 1998 F-150 (4.2 V-6), 2003 Mustang GT (4.6 V-8)
  #9 (permalink)
Old 05-16-2008, 07:16 AM
marobrown is starting off with a positive reputation.
I leave the overdrive on unless I am hitting alot of hills, mainly to control the speed on the down side. My camper is only 3000#, I barely know it's back there.
  #10 (permalink)
Old 05-16-2008, 09:28 AM
jbhford is starting off with a positive reputation.
I don't use overdrive to tow. I get the same mileage whether towing with or w/o overdrive. Besides, it is sweet pulling hills with torque converter lock up at 3,000 rpm and having power to accellerate!
Remember, trucks of the 80's (even a 460CI with 4:10 rear end) did not have overdrive trannys or locking torque converters. And I'm sure our cooling systems are better now than back then. My opinion is to lock out that overdrive and let it roar. These are not diesels, so their power is not at lower rpm.
__________________
2006 F-150 Supercab Lariat 4x4
2006 Expedition Eddie Bauer 4x4
  #11 (permalink)
Old 05-16-2008, 12:05 PM
V8EXPLR is gaining momentum as a positive member of FTE.
I agree with basically everyone here. Flat roads it's okay, hills/mtns lock it out of O/D.
Living in CO, the majority of my towing is with O/D off. Even when going through the mountains without a load the truck hunts for gears a lot. So I almost make it a conserted effort to lock out O/D anytime I head west from Denver.
__________________
Justin
2006 Ford F-150 SuperCrew XLT Chrome Edition
5.4L Flex-Fuel, 3.73LS, 18" Stock Rims, 18" BFG Rugged Trail T/A's, Trailer Tow Pkg
Sun/Moonroof, Fog Lamps, Ford Bedliner
Lund Headlight & Taillight Covers, Lund VentVisors
  #12 (permalink)
Old 06-19-2008, 11:19 PM
jtruck618 is starting off with a positive reputation.
How many more RPM's do you run with the O/D off? Say at normal driving speeds 55/65/70? Wish this truck had a tow/haul mode cause I would probably buy one tomorrow. It is my only hold out........
  #13 (permalink)
Old 06-20-2008, 10:33 AM
pb34's Avatar
pb34 is starting off with a positive reputation.
Quote:
I'm not quite sure about your question but I believe the '09 has a tow/haul mode.
  #14 (permalink)
Old 06-20-2008, 07:04 PM
My question is.....what kind of RPM's do guys run when towing?.........See my other post for further....
  #15 (permalink)
Old 06-20-2008, 07:11 PM
FLAgtSTANG302 is starting off with a positive reputation.
I all ways thought that the tow hall botton on the chebys was the same as the botton on the fords to take it out of OD
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
