if you have a lathe or a drill press, chuck the buffing wheel up in that and and slow the wheel down to a good buffing speed and buff it with mothers polish.
The only thing I have is a drill and a air cut off tool.
I wonder how I can polish up the Aluminum surround before I paint the grill inserts?
If you search the forums and use the term polishing anodized trim, you will find a LOT of information on how to get rid of the oxidation. The real key is to get it shiny and then shoot it with several coats of clear to prevent oxidation from returning as quickly. Other option is to take it to a chrome / aluminum shop and have it polished (mine ran $300 but they removed all scratches and dings). It is now getting sprayed with professional grade clear. Still cheaper than a new $600 grille surround.
BTW-I used Krylon "Argent" Steel Wheel paint on my plastic inserts and 4 coats of clear over them. they look fantastic.
The fun part will be a few dents,scratches and tears in the surrounds. But the grill inserts look like a good cleaning will work. I'll look up the polishing trim here a little later.
If you are going to do it 'argent', may I suggest the 'cheap' aftermarket grill shell. I bought one for my truck. It's not shiny, but more of an unpolished aluminum. With some tweaking, I'm happy with the fit.
