Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Modular V10
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 05:02 PM
Mmaxed is starting off with a positive reputation.
Ignition timing
Does anyone know where the timing should run on a '08 V10?
I just got a Scan Gauge and watching the timing is kind of interesting. With the cruise set on 70 mph it will run from 28 to 40 degrees. Mostly 29-32. A small hill or more wind that requires more throttle and the timing pulls back. The only time it will go above 32 is when only very light throttle is needed to hold speed.
Is it normal for it to pull back like that? I'm using premium fuel, so it shouldn't be sensing knock. Is this range what should be expected?
__________________
2008 F-250 Lariat, CC, LB, V10, 4.30s
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 07:05 PM
fordmdb's Avatar
FTE Sponsor
fordmdb is starting off with a positive reputation.
Yep what your reporting is normal
__________________
www.5startuning.com
SCT Custom Tuning Dealer
Mobile Dyno Services
Come Visit the South Carolina Chapter here!
2005 V10 F250 CC , 2005 F150 Std. Cab , 2006 Ford 500 , 2002 GT Stang
  #3 (permalink)
Old 05-14-2008, 08:31 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
That's where the low-end torque comes from, retarding the timing like that.
I did the same thing, with a 390 I built with 11:1 compression and lopey cam, very prone to pinging.
I reversed the standard vacuum advance to actually retard the timing when I apply the go-pedal. It worked out great, getting lots more low-end torque than I could have any other way.
Normal, I'd think.
__________________
- art k. - Moderator for the Superduty, V10, and FE-series forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 4x4 435NP 205NP deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 05-14-2008, 09:02 AM
[quote=krewat;6152818]That's where the low-end torque comes from, retarding the timing like that.
quote]
If that's true it should be retarding alot more. On Sat I got the wiring done for the trailer and hooked up the 5er for a shake down cruise. The only place I could run OD was on a slight downhill. On the level with no wind at all, maybe.
The other thing I didn't like with the 5er was the downshifts. It is kind of a double shift or a stutter. Fairly harsh.
I hope I don't sound like I'm complainig. I want to learn what is out there to improve things. Thanks for the responses.
__________________
  #5 (permalink)
Old 05-14-2008, 02:24 PM
fordmdb's Avatar
FTE Sponsor
[quote=Mmaxed; On Sat I got the wiring done for the trailer and hooked up the 5er for a shake down cruise. The only place I could run OD was on a slight downhill. On the level with no wind at all, maybe.
The other thing I didn't like with the 5er was the downshifts. It is kind of a double shift or a stutter. Fairly harsh.I hope I don't sound like I'm complainig. I want to learn what is out there to improve things. Thanks for the responses.[/QUOTE]
You were you using tow/haul mode right?
__________________
www.5startuning.com
  #6 (permalink)
Old 05-14-2008, 02:34 PM
Yes, using tow/haul. I think that the shift is slow/harsh because of the system thrying to make it smoother by pulling power for the shift. It didn't matter if I used just enough throttle to force the shift or pushed hard on the right pedal. Shift felt the same.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
