Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 04:21 PM
gvrangr98 is starting off with a positive reputation.
Question the "CLU - CLUNK!" sound.
98 3.0 makes a clu - clunk sound when shifting from P to D. Then when I step on the gas pedal I get what seems like a delay, or hesitation kinda. To me... it seems as though it is some where in the drive train, behind the trannie, maybe where the drive shaft connects to the Gear box?
It's hard to explain... feels almost like the rear differential/axel/wheel assembly are trying to "catch up" with the drive shaft. there is a definate delay and clunk sound when i depress the pedal with normal to slow preasure. (I'm affraid to 'gun it' for fear I'd just make thing worse!)
Any one want to diagnose this one?.....How long do I got Doc? (now for the scariest question of them all) HOW MUCH $$$ ?
__________________
1998 Ford Ranger XLT 4X4 KingCab Stepside
Vulcan V6 3.0 Automatic
Customized K&N Cold Intake
Customized 2.5 in. CatBack by "Lou's Custom Exhaust"
245/70r16 BFG OpenTrail T/A's
213,565 "New England" miles and climbing
1994 Saturn SC1
249,478 "New England" miles and running strong!
38 MPG (Daily)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 05:10 PM
5.0B2 is starting off with a positive reputation.
Check your transmission fluid level
__________________
1965 Falcon Ranchero hiPo 289 9"
1979 Lincoln Versailles 351W 4v
1984 BII 5.0FI 4R70W B/W 1356 d35 & 8.8/disks
1997 Explorer Sport 4.0 OHV
  #3 (permalink)
Old 05-13-2008, 06:03 PM
ATF you mean? the level there is up to par, definately.
  #4 (permalink)
Old 05-13-2008, 06:05 PM
bazzman1953's Avatar
bazzman1953 is starting off with a positive reputation.
Check your rear spring shackle mounts, they are probably gone. Mine are, even though there is no rust elsewhere. This is an all too common problem with older Rangers.
__________________
'94 Mazda B4000 SE 4.0L 4x4 M5OD X-cab
"YOU DON'T NEED A BLOODY CHERRYPICKER TO GET THINGS OUT OF THE BED"
  #5 (permalink)
Old 05-13-2008, 09:17 PM
Dad's Truck is starting off with a positive reputation.
U-joints are going, or there's slop in the diff.
__________________
Dave
'99 B2500 SE
'92 F-150 XLT - dad's truck- gone but not forgotten.
12/27/32-08/06/04
  #6 (permalink)
Old 05-14-2008, 03:48 PM
Quote:
U joints you say? there is more than one? how many are there? costly?
I'd like to think this is something I can repair myself. anyone done the universal joints before?
__________________
1994 Saturn SC1
38 MPG (Daily)
  #7 (permalink)
Old 05-15-2008, 12:56 AM
epion04 is starting off with a positive reputation.
as to how many ujoints it depends, 2wd or 4wd and if you have a single or double cardigan joint. if you have then single card. joint and 2wd it should be 3 ujoints if it is the double card. then you will have 4 this is assuming a 2wd. if it is 4wd then there will be at least a couple prolly more in the front shaft too. although those will not have any impact on the park to drive shift unless you use 4wd all the time and then there are other problems you will cause. if you are gonna do the ujoints yourself then hope for the single card.s they are much easier to work on than the doubles
cost is not too bad. just did the ujoints on my truck (2wd single card. 91 ranger) all 3 of mine ( the greaseable type) came out to around $30
  #8 (permalink)
Old 05-15-2008, 06:31 AM
the truck is 4-WD I don't know the difference between single or double cardigan. but if it helps it a 98 3.0 4-WD supercab "off road" package.
  #9 (permalink)
Old 05-16-2008, 07:54 AM
He means 'cardan.' Cardigan is a sweater.
LOL
__________________
Dave
'99 B2500 SE
12/27/32-08/06/04
  #10 (permalink)
Old 05-16-2008, 08:08 AM
bluedevil3758 is starting off with a positive reputation.
it might be u joints but try wiping all the old grease off the slip yoke and putting new on, its a common problem with the rangers... and this only takes a few min and some regular grease
__________________
1999 ranger 3.0l 4x4 4.10
2005 f150 2wd 5.4 scab 3.73s
  #11 (permalink)
Old 05-16-2008, 11:18 AM
pgw85706 is starting off with a positive reputation.
Have you considered the driveshaft slip yoke?
http://rockledge.home.comcast.net/~r..._Yoke_Lube.pdf
http://www.ford-trucks.com/forums/10...-anything.html
__________________
'99 SCAB XLT 3.0L FFV M5OD 4x4 w/ off-road
  #12 (permalink)
Old 05-16-2008, 05:59 PM
mfp4073 is starting off with a positive reputation.
I am voting for slip joint, with u joints in second.
__________________
please do not take any of the above advise as that of an expert!
99 3.0 auto ext cab stepside 4x4
  #13 (permalink)
Old 05-17-2008, 08:51 PM
slip yoke.... i called "Townsend Ford" (a local dealer) the quoted me $68.95 for a new slip yoke. Think getting a new one is the way to go? How about after market? Is replaceing the slip yoke difficult and will it take all day long???
There is also the slip yoke boot. Does that or should that be replaced at the same time?
  #14 (permalink)
Old 05-17-2008, 11:01 PM
NNOOOOOOOOOOOOOOOOO, take it apart, clean and lube and reassemble!
__________________
  #15 (permalink)
Old 05-18-2008, 03:58 AM
NNOOOooooooo....it is a simple maintenance task. Read the TSB in the reply I provided. You should purchase from the dealer the special grease mentioned in the TSB.
Pat
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
