Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 02:54 PM
triton54's Avatar
triton54 is starting off with a positive reputation.
E4OD Question
Hello yall, quick question for you experts. I have a 97 F-250 4x4 LD with the 5.4. It has the E4OD and it just turned 109,000. Well i had some issues with it shifting weird , slamming in and out of different gears, o/d light flashing. Long story short i had it rebuilt for 2k, I had them add a cooler to it as well. I probably let them make a few bucks off of me. Well i get the truck back and drive it about 25 miles on the highway and it starts slamming into every gear again. Turned the truck off, started it up and it was fine....another long drive (20 + miles) on the freeway and it did it again. Took it in, they cleared the codes for the speed sensor. Drove to work today and it did it again, now he says being i have oversized ties and a lift (3" suspension lift, 35" tires) and my speedo wasnt calibrated that that will throw a code for the speed sensor until i calibrate it. Is he blowing smoke or is it a legit statement? I'm only 8mph off and i'll calibrate if need be but someone arm me with knowledge please.
__________________
1997 F250 LD 4x4
35" Buckshots
3" Rancho Lift
New trans and T-case at 111k
  #2 (permalink)
Old 05-13-2008, 08:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.
He's blowing smoke. You still have a problem with the speed sensor. Either the sensor is bad, or the wiring to the sensor is broken or shorted, or the target wheel in the diff that the speed sensor looks at is damaged.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
