Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 02:53 PM
graven57 is starting off with a positive reputation.
a/c compressor does not engage
1989 Ford F250 7.5L
Where do I start at diagnosing why my A/C compressor quit engaging. Are there fuses that control it? It use to work, I have owned the truck since 1992. When it did work the compressor was noisy when it enaged, I'm guessing it just went out and I need a new one. Any help would be appreciated, thanks!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-13-2008, 03:01 PM
adrianspeeder is starting off with a positive reputation.
Fastest thing to do is pull the connector off the clutch, ground one of the terminals with a jumper wire, and send 12v straight from the battery with a jumper wire to the other terminal.
If nothin happens, ac clutch bad. Get a click, we can start troublshooting wires.
Adrianspeeder
__________________
02 F250 PSD, 97 F150 4.6, 87 F150 300, 79 F100 302, 71 F100 302, 66 F250 352
92 Bronco 302, 89 Bronco 302, 88 Bronco 302, 84 Bronco 351HO
  #3 (permalink)
Old 05-13-2008, 03:18 PM
alz alz is offline
alz is starting off with a positive reputation.
If freon is low, it won't engage. You may have a leak. There should be a pressure switch. If you were to jumper the terminals and it works, you are low on freon.
__________________
1995 F150 4x4 SC 302 4R70W MAF
  #4 (permalink)
Old 05-13-2008, 04:23 PM
quicklook2's Avatar
quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.quicklook2 has a good reputation on FTE.
only do the jumper thing for a few seconds or you will only compound the problem.
__________________
"The essence of knowledge is, having it, to apply it; not having it, to confess your ignorance." ~Confucius
  #5 (permalink)
Old 05-14-2008, 08:40 AM
Quote:
I will try this and let you guys know, thanks for the feedback
  #6 (permalink)
Old 05-14-2008, 10:27 AM
jroehl's Avatar
Mastposter
jroehl has a great reputation on FTE.jroehl has a great reputation on FTE.jroehl has a great reputation on FTE.jroehl has a great reputation on FTE.jroehl has a great reputation on FTE.
If you can nail down problem parts, you can replace them, but after that, let a pro oil and charge the system.
If the "only thing wrong" is that you're low on freon, you've got a leak. Let a pro find it, fix it, then recharge the system.
The pressure switch was bad in my '93, so my A/C didn't work (bad and leaking). I took it to a shop, and for about $375, they replaced the part, converted the fittings for R134a (couldn't get R12 and none of the mechanics even kept their R12 gauges at the shop any more), evacuated the system and then charged it to spec. It's been working great since--about 2-3 years now.
That's compared to my '90 where I basically sunk $400 into it with a conversion kit, several cans of R134a, then a new compressor...and still had a system that leaked out in 2-3 days. Leaks only get bigger and more expensive on A/C systems, never smaller.
Jason
__________________
-1990 F150 XLT Lariat LB 302 2wd AOD 3.55 open (former work truck, gone, but not forgotten)
-1993 F250 XLT xcab LB 351 2wd E4OD 4.10 open (parked, tranny issues)
-1989 Mazda B2200 SB 2.2L 2wd 5-speed (work truck)
  #7 (permalink)
Old 05-14-2008, 10:32 AM
quicklook2's Avatar
i concur, i let pros do my air cond. work also.
__________________
  #8 (permalink)
Old 05-14-2008, 03:46 PM
I will do that. I already had mine converted to R134 back in 2001. It cost 300+ bucks to do that. Hopefully it won't cost that again....
  #9 (permalink)
Old 05-14-2008, 04:44 PM
jroehl's Avatar
Mastposter
Well, I hate to break the news to you, but if your compressor is toast, it will be at least that much for just the compressor, no installation.
Jason
__________________
  #10 (permalink)
Old 05-14-2008, 07:24 PM
luthrobediesel is starting off with a positive reputation.
prolly low on freon
  #11 (permalink)
Old 05-15-2008, 08:43 AM
I jumped the connector off the pressure switch and the compressor fired up!! So it looks like I am low on R134 and must have a leak somewhere. Thanks for everyones help and advice!
  #12 (permalink)
Old 05-15-2008, 09:06 AM
quicklook2's Avatar
it could also be the clutch is bad on the compressor and a few other problems.
mine was full and would go on with wire but it need a new compressor to work again.
now is the time to take it to an air cond. pro to have it fixed correctly.
__________________
  #13 (permalink)
Old 05-15-2008, 09:42 AM
lsrx101 is gaining momentum as a positive member of FTE.
Not so fast guys!
AC repair is very doable by a DIYer with some basic AC knowledge. The biggest problem with DIY AC repair is lack of understanding of the system and cutting corners. The rack of "magic juice" at the parts store often gives the impression that AC repair is cheap and easy if you use these products. Sealers, boosters, stop leaks, eyc. just plain don't work except to flush your wallet. The same with the "tools" on that rack near the parts counter.
On graven57's 89, there's obviously a leak. At nearly 20 years old every o-ring in every hose connector needs to be replaced for the whopping cost of about $8. Close inspection of the compressor and condenser, hoses and hose crimps for oil or staining will uncover most other leaks. He can rent or borrow the proper tools (vacuum pump, manifold gauges, can tap, etc.) and repair the system as well as any shop.
It ain't rocket science, just a system that most folks are intimidated by until they are familiar with it. Check out Automotive AC Information Forum - ACKITS.COM. It is an excellent DIY MVAC site.
Hey, Quicklook2- Howdy neighbor!
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #14 (permalink)
Old 05-15-2008, 10:22 AM
quicklook2's Avatar
hey, back at you!
if it was leaking it needs to be evacuated and refilled and combined these two things, not including what else is wrong, is beyond the diy. imho.
__________________
  #15 (permalink)
Old 05-15-2008, 01:32 PM
bansheeduner is starting off with a positive reputation.
try the low pressure switch thats what went out on my truck a little while ago
__________________
1997 f250 7.5L 17 inch wheels custom 8" lift limo tint,tinted windshield 7" flip up w/navi 2 subs.flowmaster exauhst, k&n intake
2004 f150 super crew lariet 4x4 8" rize lift king coil overs 20" wheels and 37s banks power pack supercharger in dash touch screen 2 subs limo tint & tinted windshield
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
