Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 02:18 PM
big island is starting off with a positive reputation.
1994 NDI turbo white smoke when started
my truck has been smoking upon start up but clears up and runs o.k....any ideas?
  #2 (permalink)
Old 05-14-2008, 03:44 PM
Cuda_jim's Avatar
BECOME A ------------>
Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.Cuda_jim has a good reputation on FTE.
White smoke on start up is unburned fuel.
Probably a glow plug or two are bad or weak? Still cold where you are located?
  #3 (permalink)
Old 05-15-2008, 02:20 AM
checked the glow plugs with a test light by removing the wires to each plug and connecting one side to battery ground and the other to the glow plug and everyone checked out o.k.....anymore ideas........the weather here is not cold at all(Hawaii)
  #4 (permalink)
Old 05-15-2008, 05:21 AM
Cuda_jim's Avatar
A little white smoke at start up is normal, especially for older engines.
It may have a slight misfire and smooth out as the smoke dissipates.
An ohm meter will tell you the health of the GP.....should have less 5 ohms resistance...
  #5 (permalink)
Old 05-15-2008, 11:17 PM
bobrl13 is starting off with a positive reputation.
mine does the same thing, but it also has a kinda long crank time. It is definatly unburnt fuel, I am thinking it is an injector bleeding down overnight or perhaps the check vave in my return line at the pump not working properly.
__________________
94 idi 7.3 turbo 220k miles crewcab 4wd 5 speed 4.10 gears
  #6 (permalink)
Old 05-16-2008, 02:44 AM
my truck has only 62000 miles ....I just changed the GP controller cause I noticed some melting stuff from under the controller...don't think it had anything to do with the problem since it was still starting up but it just did not look right,looked like it might have overheated...anymore good idea's..the truck starts up quite mormal but at times (not always) it will start and run rough until the white smoke clears up.....?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
