Merc Maurader 4.6 to F-150? - Ford Truck Enthusiasts Forums
Old 05-13-2008, 02:29 PM
thewheelman's Avatar
thewheelman thewheelman is offline
thewheelman is starting off with a positive reputation.
So, I'm always thinking about how to get more out of the 4.6 in my F-150 screw. What's the difference in the 300 horse Maurader engine and our 4.6's? Throttle body? Programming? Injectors? Intake? Are there any internal differences? In other words, could I bolt on the Maurader parts and up the horsepower on my truck?
Thanks!
Old 05-13-2008, 03:53 PM
86halfton's Avatar
86halfton 86halfton is offline
86halfton is starting off with a positive reputation.
the maurader engine is a DOHC engine 4 cams, 32 valves
the intake on the maurader is better, im sure the maurader has more compression
our engines, sohc , 2 cams, 16 valves
Old 05-13-2008, 04:06 PM
Cool, so the maurader engine is the same as the Mustang, not the F-150.....I'm begining to understand.....
Old 05-13-2008, 04:14 PM
86halfton's Avatar
similar , the mustang GT engine is also known as a 2V engine, which is same as our trucks, execpt the newer GT which are 3V (which means 3 valves per cylinder) variable cam timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
