05 F150 Front end noise
My 05 F150 with 50K miles started making a hum or Grrrr sound from the front end. It is not coming from the engine. When I take my foot off the gas (so I dont hear the exhaust system) you can hear the sound. It continues and gets more noticable as the car coasts to a stop. Any ideas???
That was my first guess, a wheel bearing. If you jacked it off of the ground and gave it a spin, you will know right away. If it is suspect, I replace them. Sometimes if you brake hard, they will get louder, if they are fronts. On the older vehicles, sometimes they just needed to be tightened up and regreased. Look for blue or black coloring, indicating it got hot. (Cracks, spalling, in extreme cases)
The noise is back
Well. I replaced the driver side wheel bearing a few month ago and it seemed to take care of the problem. I thought I could still hear the sound if I listened close. Today the sound is back and getting louder. Not sure where to go now. Would moisture in the vacume lines eventualy cause a bearing failure??
Don't know if this helps but I have a 4x2 that has been making the same noise for a while. Brought it to the dealer for help. I let them listen to it while costing/ lightly turning the steering wheel at a stop light will make the low "grr" sound as well and the truck has to be in drive, if its in nuetral it won't make the sound. They told me to bring it to a different service center to have it looked at. Didn't have time to do it so I am still waiting to get it looked at.
escapedtwice
Escape & Escape Hybrid
07-23-2013 09:53 PM
dan1101
10-06-2004 09:30 AM
JJH
12-09-2002 05:16 PM
