Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 01:21 PM
kmcmurph is starting off with a positive reputation.
97 Explorer O/D off light- Temp Related?
Has anyone come across a random overdrive off (O/D) light blinking on the dash?I have a 97 Explorer XLT, 4.0 sohc, 219k miles. The transmission runs great otherwise and the rpm's do see to come up a bit when the light blinks on the dash, but if I push the OD button to off, the rpms really come up like it is truly off. The light also seems to be temperature related, because it will go off when the truck is cold, but come on after driving for awhile. I am stumped. Can the overdrive be related to the temperature of the coolant or oil?
  #2 (permalink)
Old 05-13-2008, 01:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.
When it blinks is it on/off/on/off at a steady rate? If so, it means an error code was stored in the computer's memory. You need to have the code read to determine what's wrong.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #3 (permalink)
Old 05-14-2008, 12:40 AM
Had the code before I swapped out rear ends, undid battery cable to bleed brakes, code came back, could it be hard code?
  #4 (permalink)
Old 05-18-2008, 11:46 AM
beater79's Avatar
beater79 is starting off with a positive reputation.
sounds like your tcc valve is sticking.
__________________
79 F-150 short bed, 400m, 4spd, 4x4, 4" rancho lift
96 explorer 4.0 auto, k&n filter, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
